Author: Subject: ZZR1100 Keihin CVK Carb Question....
r1_pete
posted on 9/11/08 at 08:59 PM Reply With Quote
Adjusting the pilot circuit, am I right in my thinking, screwing in richens the mixture, i.e. reduces the airflow to the pilot jet thus increasing fuel flow?
- You can tell I'm trying to convince myself, just as I'm getting some odd results.
Cheers.
Pete.
[Edited on 9/11/08 by r1_pete]
Roman
posted on 9/11/08 at 09:53 PM Reply With Quote
I would say you are right, but have a look here, it's full of useful information on the Keihin CVK carbs.
Memphis Twin
posted on 9/11/08 at 10:33 PM Reply With Quote
On a CV type carb screwing the pilot screw in will normally weaken the mixtureas it works on the fuel delivery. On a slide type carb (ie not a constant depression type) where the slide is lifted mechanically, screwing the pilot screw in will richen the mixture as it works on the air bleed.
Cheers.
