Author: Subject: rear gearbox mount 750MC Locost
evanschris
posted on 14/11/08 at 01:57 AM Reply With Quote
Hi, I am building a racer with my students based on a Stuart Taylor chassis. Question is if I bolt the rear gearbox mount through the chassis will this be strong enough. I would like to bolt rather than weld as this would mean easier box changes in battle conditions. I seem to remember welding the last one in place. Anyone with any pics of their installation would be welcomed. We run the escort mk 2 gt box in Locost in case anyone was wondering.
procomp
posted on 14/11/08 at 07:58 AM Reply With Quote
Hi.
The easiest and best for stability wise way to mount the gearbox is..
To use the old Anglia mount. Or as you will never manage to find one Caterham have there version made for them. All it needs then is a piece of steel strip bolted to the base of the mount wich then bolts to the strips of steel either side of the tunnel in the chassis. Quick and easy and this mounting provides stability for the gearbox unlike the sierra type which allows the box to move all over the place.
LINK HERE
Cheers Matt
Edit. OK so the site will not allow access straight to the catalogue online. Use part number EM429 in there search. Top right of the page linked above.
[Edited on 14/11/08 by procomp]
evanschris
posted on 14/11/08 at 11:10 AM Reply With Quote
Cheers Matt. Dont suppose you have a picture of the steel bit do you . I "think" I have on of those - I was wondering whether the tubing was up to the side forces imposed , as its only 3/4inch or whether I need to weld in some crush tubes to re-inforce?
