Author: Subject: Small Pulleys
prelude1980
posted on 18/11/08 at 06:48 PM Reply With Quote
Small Pulleys
Does anyone know what cars might have a small pulley for a 6 groove belt. I need to speed up my alternator
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
big_wasa
posted on 18/11/08 at 06:49 PM Reply With Quote
How small is small ? The standard Mondeo one is small.
prelude1980
posted on 18/11/08 at 07:05 PM Reply With Quote
needs to be smaller than the 85mm dia one i have now.
50mm would be good
gets you.
r1_pete
posted on 18/11/08 at 07:44 PM Reply With Quote
VW Beetle, take a look in my archive I made my idler out of a beetle alternator pulley.
big_wasa
posted on 18/11/08 at 07:49 PM Reply With Quote
Like I say I am sure the 2L silvertop has a small pulley.
The one I have.
48mm across the ribs and 53mm total dia with a 17mm none keyed bore.
big_wasa
posted on 18/11/08 at 07:50 PM Reply With Quote
pic2
posted on 18/11/08 at 08:00 PM Reply With Quote
Spin the alternator too fast and the wires from the rotor windings will break away from the connection to the slip rings --- 1.5 times crank RPM is about the norm. An alternator should be at near its normal rated output if the alternator rotor is spinning at 3,000 to 3,500 rpm.
posted on 18/11/08 at 08:16 PM Reply With Quote
BT is right; check the haynes manual for max alternator rpm; you will find it is a bouot 12,000.
If the Rover V8 is anything to go by, the crank/alternator pulley diamters are 2:1.
prelude1980
posted on 18/11/08 at 08:22 PM Reply With Quote
mondeo one looks good,
the pulley i have now is quite big, the max rpm on my alternator is 13,000 rpm.
any ideas where to get a mondeo one short of buying a whole alternator off ebay or something
gets you.
big_wasa
posted on 18/11/08 at 08:49 PM Reply With Quote
You can have this one but it may take me a bit to get it posted.
stevebubs
posted on 18/11/08 at 09:15 PM Reply With Quote
Local Ford Parts dept?
or go on fleabay / boy racer site and get an anodised one...
posted on 18/11/08 at 09:48 PM Reply With Quote
I e-mailed an Ebay alternator refurbisher and he sent me 3 of various sizes to me for my supercharger installation for a tenner. Did the job for me...
