Author: Subject: How to drive a diesel tacho
it_cud
posted on 19/11/08 at 09:27 PM Reply With Quote
Hi,I'm putting a diesel engine into my Westfield and want the VDO tacho to work.I don't have an ECU and have been advised it could be done using an LM1815 conditioner board.But how ? Also considered using a EDIS module but requires coils to be operational. Any advice / suggestions would be greatly appreciated.
Thanks, mike.
dinosaurjuice
posted on 19/11/08 at 10:08 PM Reply With Quote
what engine are you using? i presume its got a mechanical injection pump?
i dont have a tacho yet, but intend to use a magnet on pulley and pushbike style pick up. going into a vapour digidash. might have to introduce some kind of op-amp if the signal is too weak.
not sure how else to do it. some SVA centres have a vibration sensor to accurately check rpm for noise test, but that sounds expensive....
will
mark chandler
posted on 19/11/08 at 10:18 PM Reply With Quote
Most diesels run the tacho from the alternator, just take a tap out before the regulator.
