Nosey
| posted on 20/11/08 at 09:46 PM |
C20XE Distributor
Well lads, just trying to fit a H&H distributor to the Vauxhall engine and there is a small ball bearing in the end of the exhaust cam. H&H
reckon it should pop out with a magnet but there's not a budge. Any suggestions? (was thinking of whipping off the cam cover and seeing if there
was any to put an airline and blow the little sucker out?)
NS Dev
| posted on 20/11/08 at 10:59 PM |
hmm, shouldn't be one on a C20XE as std, someone may have blanked it off.
No, a magnet won't shift it as it is there to hold back 60 psi of oil pressure.
Easiest to get a used exhaust cam from an engine with no plug in there, which is most of them (all ones with dizzy as std)
I have a cam I can post if you want, yours for the cost of post
Nosey
| posted on 21/11/08 at 08:47 AM |
No idea why there is two of my posts here...
[Edited on 21/11/08 by Nosey]
