Author: Subject: Any deisel engine specialists/guru's on here...?
carpmart
posted on 27/11/08 at 04:21 PM Reply With Quote
Chaps
I have a Sprinter van 311 cdi 2001 which died on me whilst the engine was idling. The engine was warm and had been in use for a couple of hours of driving before it stalled. Its been a pain in the arse to start recently with quite a bit of cranking required to get it to go.
My thoughts (I am far from an expert with diesels) is fuel pump(s) or injector(s)
Anyone else want to have a go at diagnosing the fault? Anyone able to give me a maximum and minimum repair bill cost estimate so I know how skint I will be at Christmas.
Can anyone recommend a diesel specialist in North Bedfordshire?
I know your all going to say it needs hooking up on the diagnostics to tell the fault but I hoped you may have opinions/experience which can help me out!
Thanks in advance
[Edited on 27/11/08 by carpmart]
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
bigrich
posted on 27/11/08 at 04:29 PM Reply With Quote
its probably the fuel pressure reg O ring and plastic spacer that has split VERY VERY common and about a 5er for bits, just need to remove the inlet to access the reg at the rear of the fuel rail.
Takes less than an hour to do just need a small rachet and some E torx bits
carpmart
posted on 27/11/08 at 04:43 PM Reply With Quote
bigrich
Thanks for the quick reply. Sounds like you have some experience of this?
Have you a link to anything on the web which can give me some more detail on how do this job? Have you a part(s) number so I can order the necessary.
Thanks again!
'94 MX5 MK1, 1.8
Wadders
posted on 27/11/08 at 05:00 PM Reply With Quote
I'm with bigrich on the diagnosis, although i did once have a cam sensor go, which gave identical symptoms.
If you tow start it, it should run ok, just don't switch it off.
Injectors are also prone to go on the 311, and are silly money.
Al
bigrich
posted on 27/11/08 at 05:03 PM Reply With Quote
we just order the bits from Merc who always have them in stock (wonder why)
I have done quite a few and its a fairly easy jobwith just a couple of bolts to undo by feel at the back of the inlet manifold
hillbillyracer
posted on 27/11/08 at 07:39 PM Reply With Quote
A thing I've seen happen on a Vito with a common-rail diesel is the O ring on top of the fuel filter leaking air into the system, it gave similar symptoms that you have. Although the Sprinter is a different animal the fuel system may well be similar.
A smear of grease on the O ring had it right.
A mate who deals in & maintains vans said he only uses genuine Merc filters now because of it.
carpmart
posted on 27/11/08 at 08:58 PM Reply With Quote
Thanks for all the replies chaps!
I'm a bit of a numpty with CDi engines at the moment. Is there the equivalent of a workshop manual available for this engine?
On-line and free would be even better than one I have to buy but a link to anything would be very appreciated!
'94 MX5 MK1, 1.8
