Richard Quinn
| posted on 27/11/08 at 07:13 PM |
Weld-in ally fuel filler neck - cap
A few months ago I'm sure that I saw somewhere advertising weld-in ally fuel filler necks / caps for less than £10. But I've slept since
then and can't for the life of me remember where it was. Does anyone remember where it was? I know that CBS and Merlin do some at £17 ish but my
mate has about 10 fuel/oil tanks to do and it adds up to a bit of a saving.
TIA
andylancaster3000
| posted on 27/11/08 at 07:20 PM |
Rally design:
http://www.rallydesign.co.uk/product_info.php?products_id=4554
Richard Quinn
| posted on 27/11/08 at 07:27 PM |
Nice one! Don't suppose there is anywhere cheaper??
big_wasa
| posted on 27/11/08 at 08:21 PM |
There where a few on ebay a bit back.
nitram38
| posted on 28/11/08 at 03:50 AM |
Don't forget the unleaded restrictor required if you have a CAT fitted. Generally these filler caps are just pipe so you might have to weld in a
smaller washer type disc inside before fitting.
Richard Quinn
| posted on 28/11/08 at 07:46 AM |
These particular tanks are for motorsport use only. I know what you mean though as I have this type of filler on my own tank. To avoid splashing I
generally fill from a jerry can via a funnel so it doesn't really matter if there is a restrictor there or not. When was the last time anyone
saw leaded petrol available from a pump on a forecourt anyway???
procomp
| posted on 28/11/08 at 08:12 AM |
Hi
If you go for the larger size from rally desighn ( which is just about the cheapest supply ) you get the O'Ring seal with the cap. If you go for
the smaller size you DO NOT get the seal with the cap. However i can give you a load if required. I have a rudy great box of em and now i only use the
larger size .
Cheers Matt
Neville Jones
| posted on 28/11/08 at 09:22 AM |
quote: Originally posted by Richard Quinn
When was the last time anyone saw leaded petrol available from a pump on a forecourt anyway???
On the road from Romsey to Salisbury, last Monday. Sells 5 star as well.
Also on the A303 on the way to Exeter. A BP before you go down to the lower sections.
Nev.
Richard Quinn
| posted on 28/11/08 at 10:48 AM |
My bad! Who says it's grim up north where we must all drive newer cars?
