Benzine
| posted on 27/11/08 at 09:33 PM |
"It nearly started"
Not my words, the words of Shakin' Stevens!*
*my mum
Yesterday I put in another engine that came straight from a car that it was running in (so it's all timed up nicely) My injectors are all
working, I'm getting very strong sparks but it's not starting. It's trying to, seems like a few cylinders are going yes, yes, yes!
then the others slow it down. I'm running EDIS6 and I installed the triggerwheel as per the instructions.
Firing order is 1-5-3-6-2-4 and I have my leads arranged like:
What are the basic things I can check? Must be overlooking something... it was spluttering, really wanting to start. So close!
Thanks for all the help everyone ^__^ <3
Paul (Notts)
| posted on 27/11/08 at 09:40 PM |
Could be totally wrong BUT I thought the coil fired ABC order
if it does then your leads on B and C are the wrong way wround.
need to check with info on megasuirt or jolt site.
Paul
omega 24 v6
| posted on 27/11/08 at 09:44 PM |
Check that the coil triggerring is in the right sync.
i.e you will have 4 cable's (not plug leads) at the coil. 1 live and 3 trigger wires. Two of them could be mixed up causing the yes yes, No No,
no no scenario.
swap No No with no no and you'll get yes yes yes yes.
confused?????? I can't explain it better at the moment.
rost
| posted on 27/11/08 at 10:10 PM |
I second both replies above, the trigger wires correspond to the 3 banks on the coil, you might want to doublecheck them against the MS pinout. As
Paul says, it sounds like it triggers ABC while you wired it ACB.
Charlie don't surf!
Benzine
| posted on 27/11/08 at 10:20 PM |
Yeah that's definately something to try in the morning! I recently mentioned the coil wires in another thread I found. I'll paste from
there:
quote: Originally posted by Benzine in an old thread
but according to the diagram I haven't wired it up right.
Note the big and the small tabs on this connector
According to the tabs (and this is the same on another diagram I've seen) I have it the wrong way round. So I have the switched live going to
pin 1 and pins 2,3 & 4 going to the coils. I'm still getting sparks, i think on all plugs... so will the coil order be messed up because of
this connector's wiring?
What I found weird about the connector is that one of the connectors (terminal 1) has thicker wire than the other 3. So maybe I should wire it back to
how I had it to start with (no problem as they're all bullet connectors)
I'll try in the morning! (could do now but dad is off to Belgium at 3am, don't think he'd be happy )
[Edited on 27/11/08 by Benzine]
neilj37
| posted on 28/11/08 at 02:26 PM |
quote: Originally posted by omega 24 v6
Two of them could be mixed up causing the yes yes, yes, No No, no no scenario.
Sounds like engine porn to me
Benzine
| posted on 28/11/08 at 03:40 PM |
It started! **** me is it loud! ^__^ (no exhaust on) It's getting dark now so I'll film it tomorrow during the daylight. I've not
got my cooling system filled up yet either so I only had it running for a few seconds, I'll fill it up tonight and post a vid tomorrow!
Volvorsport
| posted on 28/11/08 at 04:28 PM |
cant wait !
make sure you update the turbobrickers !!
www.dbsmotorsport.co.uk
getting dirty under a bus
Benzine
| posted on 28/11/08 at 05:21 PM |
Will do ^__^ I've just finished fitting all the hoses, expansion bottle etc and filled it up with coolant. When I give it some throttle it cuts
out, is this because I haven't mapped it yet? I've just done the bare minimum to get it running so I don't know what step is next...
Volvorsport
| posted on 28/11/08 at 05:26 PM |
yeah youll need to start adding some values - is the lambda working you can data log them and it should work out what values you need .
if not , have patience .
