| posted on 11/12/08 at 12:00 PM |
supercharged diesel?
Thinking aloud...!
Why don't we see supercharged diesel engines?
Plenty of torque to drive a charger, less/no power lag - what am I missing?
Neville Jones
| posted on 11/12/08 at 12:04 PM |
Superchargers are common on trucks and commercial and industrial diesels. Turbos are more likely these days. GM were supercharging their engines from
way way back in the 1900s. Some heavy machinery even have the turbo blowing into a supercharger.
hobbsy
| posted on 11/12/08 at 12:05 PM |
There's not a great deal of lag on a modern turbocharged VNT diesel though anyway is there?
If you get max torque at 1500rpm then you can only really get it a few hundred RPM sooner surely even with a supercharger?
Else the supercharger would be running all nearly the time and sapping power the second you go above idle.
Supercharger clutch and gearing issues?
Also turbo's on diesels are very effective due to cylinder filling being very high at all times (no throttle) and so exhaust gas volume must
also be high - hence low lag?
I'm sure you could make it work but a modern VNT turbo works so well and doesn't have any real parasitic losses....
cd.thomson
| posted on 11/12/08 at 12:06 PM |
How come we aren't all using forced induction wankel engines?
I suspect, (I also expect to be corrected) that this is just linked to ease for the manufacturer. Some boffin has explained how turbo superchargers
work and that they don't sap bhp as superchargers do and so manufacturers have just all gone down this development route. Once you start using
turbos theres no need to invest in supercharger induction. (Cylinders work fine, so why bother investing in wankel engines?).
Modern diesels with modern turbos get enough throttle lag from the TPS and ECU settings to make the effect of turbo lag negligible.
Personally I think superchargers are a better idea, but its too late in production/investment terms.
[Edited on 11/12/08 by cd.thomson]
| posted on 11/12/08 at 02:08 PM |
Wankel engines are interesting, but ultimately flawed. The long narrow combustion chamber contributes to poor thermal efficiency and poor emmisions
performance. The rotor tip sealing problems still give the engine questionable longevity compared to piston engines (though they are much better
than they used to be).
Turbochargers are ideally suited to a four stroke diesel. Since a diesel has a relatively low operating RPM range, you can use a small turbo that
starts producing usable boost at 1500 RPM or so without it running out of puff as the engine approaches it's maximum RPM. The turbocharger also
wins out on overall efficiency, packaging and cost.
The most efficient diesel engines do use superchargers, but they are two strokes and require a supercharger for scavenging. They tend to be limited
to huge engines on ships, and for power generation etc.
| posted on 11/12/08 at 02:23 PM |
Good discussion gents
C10CoryM
| posted on 11/12/08 at 02:56 PM |
There have been a few good supercharged diesels for the HD truck and off road equip industry. Mostly 2 stroke.
Where do you think the classic 6-71 or 8-71 superchargers came from?
The 6-71/ 8-71 are the names of the diesel engines that they came off.
Cheers.
"Our watchword evermore shall be: The Maple Leaf Forever!"
tomgregory2000
| posted on 11/12/08 at 06:35 PM |
One word 'COST'
Simon
| posted on 11/12/08 at 07:50 PM |
Cheers.
My understanding and it has been for best part of thirty years, that those designations were for the capacity of the engine they were designed for,
such as 6 cyl of 71 cu.in.
Anyway, agree, good thread. Have wondered about it myself occassionally.
I think with the turbo (particulary the ecu controlled VNT) you can design in a bit where there will be no boost - my Espace is off boost till about
1800rpm which means car will be more fuel efficient at cruising speeds, whereas with a blower, it'll always be on boost.
Simon
C10CoryM
| posted on 12/12/08 at 03:35 AM |
Cheers.
Yep, but the Detroit Diesel 6-71 is what used the roots type blower that is called a "6-71" blower. Same with the 8-71.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=WND%2D7476P&N=700+317356+115&autoview=sku
Cheers.
NS Dev
| posted on 12/12/08 at 07:19 PM |
..................and if you want to hear one of em, click this link!
A chap I know has just bought a limespreader with one of these engines in it and he doesn't listen to the radio now, just goes deaf listening to
the engine, it just sings!!
detroit diesel truck
| posted on 12/12/08 at 07:31 PM |
The old Commer TS3 ? was a supercharged two stroke diesel IIRC it was a three cylinder, six piston engine and PPC did an article on it earlier this
year
