Sideshow_Bob
| posted on 14/12/08 at 02:07 PM |
Ford TDC Timing Pin
Do any of you guys know what the TDC ford timing pin looks like TIS Cd part no. 303-507 (or 21-210). I'm looking for dimensions ideally or where
I can buy one.
Any help would be appreciated.
mad-butcher
| posted on 14/12/08 at 05:48 PM |
If it's anything like the ford transit banana motor injector pump pin set, just use an appropriate drill bit, on the transit it's
something like 15mm to lock the flywheel and 12mm to lock the injector pump. what motor is it for and I'll try and find out from my autodata
disk
Tony
Sideshow_Bob
| posted on 14/12/08 at 06:00 PM |
Ford Zetec Se 1.7 vct (the one in the puma)
Cheers Tony
| posted on 14/12/08 at 06:01 PM |
Sealey tools do a good selection of timing pins as do Laser tools for not a lot of money.Your local motorists shop should stock them ?
Sideshow_Bob
| posted on 14/12/08 at 06:14 PM |
Cheers I'll give them a call tomorrow.
