Author: Subject: Fuel pump for Bike Carbs
dnmalc
posted on 28/12/08 at 05:32 PM Reply With Quote
I am trying to find a fuel pump to feed the bike carbs on my 1600 pinto. the fuel tank only has one connection so the system cannot be a flow and return type. Hence the pump need to have an integral pressure cut off at a sufficiently low level that it will be shut off by the float valves.
I am aware that mini and morris 1000 fuel pumps would fit the bill as they have pressure switches set at about 1.5 psi and MG which were set at about 5 psi. However these are now getting on a bit long in the tooth and I wondered if there is a more up to date candidate out there?
RichardK
posted on 28/12/08 at 05:34 PM Reply With Quote
Just get a bike fuel pump from more or less any carbed bike over 600cc, my carbs were off a cbr600 hornet so I simply got the fuel pump off that model, workes a treat.
Rich
Gallery updated 11/01/2011
RichardK
posted on 28/12/08 at 05:37 PM Reply With Quote
This looks like the same as mine although didn't pay that much!LINKY
This one maybe worth a bid though LINKY
[Edited on 28/12/08 by RichardK]
posted on 28/12/08 at 05:41 PM Reply With Quote
As said, best bet is the matching pump from the same bike as the carbs. They cutout at the correct pressure and and don't need a return.
jacko
posted on 28/12/08 at 05:44 PM Reply With Quote
Any of the bike pumps will do i used a zx9r pump
That work just like the old su type [ stop when the carbs are full ]
dnmalc
posted on 28/12/08 at 05:50 PM Reply With Quote
Thanks guys!
Is it just the pump I need or do I need the control relay as well?
ReMan
posted on 28/12/08 at 06:07 PM Reply With Quote
Just the pump.
The relay on the bike it more to do with cutting the power when the bike goes on it's side, than because it's a high current device
Most are just 2 wires (chassis and +12v) so any relay would work.
dnmalc
posted on 28/12/08 at 06:14 PM Reply With Quote
Thanks Guys.
All these answers in less than half an hour. Its clear that is cold and dark out there now.
Happy New Year
RichardK
posted on 28/12/08 at 07:46 PM Reply With Quote
I also wired one of these inertia switches in at the same time so it interupts the power to the pump in the event of a bump, didn't fancy the idea of a fractured fuel pipe emptying the fuel tank into the engine bay!!LINKY
Rich
Danozeman
posted on 28/12/08 at 07:50 PM Reply With Quote
I have an r6 pump feeding my zx9r carbs. works perfect and no need for a pressure regulator.
Dan
posted on 28/12/08 at 08:08 PM Reply With Quote
Rich
I was looking for those, so I could mention them in my previous post! I also fitted one, for pretty much the same reason. They're really easy to wire in - when they're upright and set (you have to press the top in) then the 2 wires conduct - if the car's badly hit, or rolls over, then the connection is broken. It can be wired directly into the pump wiring, or via a relay. I took the second option as I also have a security system installed - if the security's not satisfied, then there's no ignition, the car won't start, and the fuel pump's off!
posted on 28/12/08 at 10:11 PM Reply With Quote
They're more important in a fuel injection set-up due to the higher pressures... but it's still not a bad idea....
Dingz
posted on 28/12/08 at 10:37 PM Reply With Quote
I just used the standard mechanical pump and a filter king regulator at its losest setting, works fine.
Stuart_B
posted on 29/12/08 at 11:51 AM Reply With Quote
as the same, i use cbr600 carbs on my 1.6pinto and a cbr600 fuel pump, and it works great.
stuart
