Author: Subject: Engine noise
LBMEFM
posted on 4/1/09 at 08:43 PM Reply With Quote
Engine noise
I know it's difficult to diagnose engine problems without hearing them so this is a bit of a long shot. My Fireblade runs very smoothly with clean exhaust and no smoke. Performance seems ok too. However, there is a type of metalic scraping noise at the same speed as the engine revs. Any commen faults these engines suffer from.
A1
posted on 4/1/09 at 09:06 PM Reply With Quote
are your cams etc okay? you could try finding the noise with a screwdriver or bit of bar to listen for it...
jonesier1
posted on 4/1/09 at 09:23 PM Reply With Quote
engine noise
cams turn at twice engine speed,so if the noise is intime with rpm then prob not cams.
daviep
posted on 4/1/09 at 10:55 PM Reply With Quote
Originally posted by jonesier1
cams turn at twice engine speed.
NO THEY DON'T!!!
Cam turns at 1/2 engine speed.
The screwdriver/stethoscope idea as mentioned often works well.
Davie
bigrich
posted on 4/1/09 at 11:36 PM Reply With Quote
camchain tensioner or slipper pad fractured, does the noise reduce or clear at higher revs
maximill666
posted on 5/1/09 at 01:18 AM Reply With Quote
893 & 918cc fireblade motors suffer from carb chatter, where the tolerance on the carb sliders is so large they chatter at low rpm & the noise goes away above 5k rpm.
Also the 918cc motors suffer from piston slap
Both are common fireblade traits & nothing to worry about
Bobyspit
posted on 5/1/09 at 03:14 AM Reply With Quote
What Blade engine?
Where in the engine is the noise coming from? is there metal filings in your oil?
Rob
