Paul (Notts)
| posted on 11/1/09 at 05:14 PM |
Spark plug Gap – RV8
Just about to fit some new plugs on my 3.5 RV8 and wondered if I need to set the gap on the spark plug before I fit them.
Plugs are NGK BP6ES
Engine is a 3.5 Rover V8 running on Megajolt.
If I do need to set the Gap then what should It be?
Paul
second post on this as the first got deleted by mistake.
| posted on 11/1/09 at 05:43 PM |
I'd wish you'd make up your mind, posting the query, then posting it again, then deleting it then posting it again .....
GGGRRRRR!!!
0.6 mm pre '76
0.8 mm otherwise
It doesn't harm to check the gap of new plugs, most are set to 0.6 mm.
repper
| posted on 11/1/09 at 05:44 PM |
ive been useing ngk at work for years and 99.9% off the time thay are ok out off he box but ill look on auto data and get right back to you
repper
| posted on 11/1/09 at 05:55 PM |
rover v8 22D 122kw 164bhp 90/98
beru, 14r-7du = 0.8 gap
bosch, wr7dc = 0.8 gap
champiin, rn9yc = 0.6gap (c**p plugs )
ngk, bpr6e-vg = 0.9 gap
autolite, app63 =0.8 gap
Paul (Notts)
| posted on 11/1/09 at 06:48 PM |
Cheers..will check they are all the same and run with them.
Paul
