Author: Subject: Burton Power Pinto block breather - hose size?
posted on 13/1/09 at 12:19 PM Reply With Quote
Can anyone tell me the correct hose size for the outlet on this Pinto block breather supplied by Burton Power. Need to get some hose and left the breather at home.
jabbahutt
posted on 13/1/09 at 12:26 PM Reply With Quote
Afternoon Nick
Try ringing them as when I've dealt with them in the past they've always been really helpful.
Nigel
RichardK
posted on 13/1/09 at 05:30 PM Reply With Quote
I made my own so did some measurements, hang on....
Gallery updated 11/01/2011
RichardK
posted on 13/1/09 at 05:36 PM Reply With Quote
This any good for you
Rich
posted on 14/1/09 at 10:05 AM Reply With Quote
Thanks Richard - looks like I need 1/2" or 13mm bore pipe.
I see you have removed the actual can part of the original breather. I had assumed that the Burton part fitted into this can?
How difficult is it to get the can part out?pe to the catch tank.
DarrenW
posted on 14/1/09 at 10:16 AM Reply With Quote
Can bit is quite easy to remove. I just had to tap mine left and right (not too hard) until it loosened and pulled out.
Ive used the cortina style trap and plumbed that to a catch tank. Works very well (now i have correct qty of oil in sump!).
