Author: Subject: Most narrow 7" diff for cossie 2wd
westy turbo
posted on 14/1/09 at 02:38 PM Reply With Quote
Is it the 3.92? i thought that was a 4.42 or something...
[Edited on 14/1/09 by westy turbo]
alistairolsen
posted on 14/1/09 at 02:42 PM Reply With Quote
I think you get a 4.27, been some on ebay recently. They might be 6.5 inch tho if they were on 1300s and stuff.
westy turbo
posted on 14/1/09 at 02:45 PM Reply With Quote
Hey Miger ! thanks for the info!
mookaloid
posted on 14/1/09 at 02:46 PM Reply With Quote
I'm sure 3.92 is the lowest 7" commonly available - although I believe quaife or someone make a 4.44 or something like it for a few grand!
If you go to 7.5" you can get lower ratios like 4.42 I believe.
mark
westy turbo
posted on 14/1/09 at 02:48 PM Reply With Quote
So the 7.5 is a straight swap?
mookaloid
posted on 14/1/09 at 02:52 PM Reply With Quote
The case is altogether bigger although you could mod your chassis to fit one.
You might be able to make up some hybrid shafts as I'm not sure the flanges are the same.
I know some sierras use the 7.5" diff and I understand people have used them in Indys etc
mcerd1
posted on 14/1/09 at 03:02 PM Reply With Quote
7.5" has a bigger/wider casing (has a different rear beam when fitted to the sierra)
the 4.09 and 4.27 ratio 7.5" diffs are found in 2.0 8v and 16v scorpio's (the ugly bug-eye ones 95-98) these have 100mm bolt-on CV's (the same as the 4x4 sierra's etc)
but the shaft lengths might be different :?
this lot make 3.14, 4.1, 4.44 and 4.7 ratio's for 7" click
raceline sell them: click
[Edited on 14/1/09 by mcerd1]
alistairolsen
posted on 14/1/09 at 03:10 PM Reply With Quote
http://cgi.ebay.co.uk/ford-sierra-rear-diff-4-27-1-rare_W0QQitemZ180317213838QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item18031721383 8&_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A13|39%3A1|240%3A1318
looking at that it looks like a 7.5 inch case.
sorry
westy turbo
posted on 14/1/09 at 07:28 PM Reply With Quote
Thank you all for your help!
NS Dev
posted on 14/1/09 at 07:40 PM Reply With Quote
just to second post about raceline (they are not the only suppliers, SBD used to do them too)
many alternative 7" sierra CWP's are available, just depends on your budget as they ain't std ford ones!
NS Dev
posted on 14/1/09 at 07:44 PM Reply With Quote
PS if you have an LET how can you use much over a 3.9:1 anyway????????????????????????????
We have an RWD opel kadett with LET making around 375hp and in that car which weighs around 800kg with 3.4:1 diff and it still lights up yokohama A048R tyres instantly in every gear no matter how gentle you try to be......we're currently trying to map some boost progression into it using a proper ECU instead of the Bosch Motronic!
westy turbo
posted on 14/1/09 at 08:28 PM Reply With Quote
For mine i have a 3.62 and a 3.92 will be on MBE 967E and a AVCR will do the rest,the diff that was asking is for my friends 3door sierra cossie,that sees quite often some drift events
Liam
posted on 14/1/09 at 08:42 PM Reply With Quote
Unless it's been changed at some point, a 2WD cossie has a 7.5" diff anyway. With the larger CV joint flanges, too.
Liam
westy turbo
posted on 14/1/09 at 08:48 PM Reply With Quote
Didnt know that thanks..
repper
posted on 14/1/09 at 08:59 PM Reply With Quote
if my memory serves right the 7.5 diff in the granarder are not LSD as the cars had T,C in stead i nearly got cort out my sen but i checked it befor handing over my cash . some pepole are t**ts
a good 2WD 7.5LSD from a cosworth will be about £350 ish
Liam
posted on 14/1/09 at 09:19 PM Reply With Quote
Yep - standard for a 2WD cossie is 3.64 7.5" LSD with bigger flanges/CV joints than any other models (even the granada 24V cossie has the standard sized flanges/CVs). So you're drifting buddy can probably pick up a scorpio 4.09 or 4.27 7.5" and use the crownwheel and pinion in his standard 3.64 LSD.
I only say probably cos I'm not 100% sure if there aren't any silly changes in crownwheel thickness or whatever in these late short ratio scorp diffs. This is certainly a common trick in 7" diffs to create non standard ratio LSDs, so I see no reason it wouldn't apply to 7.5"s. Just best check it out to be sure.
Liam
[Edited on 14/1/09 by Liam]
westy turbo
posted on 14/1/09 at 09:21 PM Reply With Quote
Kinda confused now...so was been in a granade as 7.5 non lsd and in cossie 2wd 7.5 with lsd?
Liam
posted on 14/1/09 at 09:25 PM Reply With Quote
Yeah most grandads have 7.5" non LSD. Only the pre-bugeye 24V cossies have a 7.5" LSD, but then that has standard sized 100mm diameter flanges/CVs. Your mates 2WD cossie sierra has 7.5" LSD with 108mm flanges/CVs and big fat shafts.
Liam
westy turbo
posted on 14/1/09 at 09:48 PM Reply With Quote
Cheers Liam
westy turbo
posted on 15/1/09 at 11:44 AM Reply With Quote
any clue what a 4.44.1 crown pinion on a 7" diff top end speed will be?
mcerd1
posted on 15/1/09 at 11:57 AM Reply With Quote
here's a gear calc program linky
but remember, your engines only got so much power - gear calc programs just tell you the max speed at max rpm and assumes you've got enough power to get there
I found this one on google: linky
but I don't know how accurate it is
[Edited on 15/1/09 by mcerd1]
westy turbo
posted on 15/1/09 at 12:10 PM Reply With Quote
Thanks but doesnt work...
