Author: Subject: Float height of zx9r carbs
Danozeman
posted on 21/1/09 at 12:58 PM Reply With Quote
Would anyone happen to know the standard float height for zx9r b carbs?
Dan
mcerd1
posted on 21/1/09 at 01:02 PM Reply With Quote
I'll look up the haynes book later (unless someone beats me to it)
posted on 21/1/09 at 01:42 PM Reply With Quote
14mm with the float resting against the needle but not pushing the little pin in.
More critical is getting them all the same as you can raise and lower the float height slightly to enrichen or lean off the rev range.
whitestu
posted on 21/1/09 at 02:40 PM Reply With Quote
How does the float height affect the mixture?
Stu
Danozeman
posted on 21/1/09 at 07:36 PM Reply With Quote
It affects how much fuel is squirted up past the needle.
Ill take my carbs off again and measure it. whats the best way to measure the height? With the carbs upside down or sideways?
Dan
whitestu
posted on 21/1/09 at 08:39 PM Reply With Quote
This looks like a clever way to check actual fuel level in each carb.
Link
Stu
