hellbent345
| posted on 22/1/09 at 11:17 AM |
sierra dohc plenum removal
Hey everyone, i have a sierra 2l dohc (heavy engine i know) and trying to remove the intake plenum to modify, clean etc. I think ive removed all the
torx bolts, i cant see any around the flanges, but it seems to be stuck solid still! do i crowbar it off or smash it off with a lump hammer, or is
there a special way to remove it? thanks al
Mr Whippy
| posted on 22/1/09 at 11:33 AM |
Double / triple check there are none missed, then get a block of wood and place that somewhere substantial and thump the wood. Don't do one huge
whack, just lots of lesser ones down and upwards. Don't use a crow bar you'll mark the mating surfaces. Take your time
bbwales
| posted on 22/1/09 at 11:55 AM |
Check that you have undone the 2 nuts holding the thermastadt housing on, you will find that it is integral to the whole inlet manifold.
Regards
Bob
hellbent345
| posted on 22/1/09 at 12:33 PM |
sh*t on ma baaaaaaaaaaaaaalls mr garrison! i havent done removed the thermostat housing :| lol i suck. thanks chaps!
PaulBuz
| posted on 22/1/09 at 06:50 PM |
Ah, a fellow dohc user!
Don't beleive the hype, its not as heavy or useless as some would have you believe
Paul
hellbent345
| posted on 24/1/09 at 05:24 PM |
hello fellow dohc user! i didnt think there was any others out there! how are you finding it? any probs with the engine, things i need to change look
out for? i noticed on both the rocker covers i have ( i have 2 engines lol) the plastic around some of the bolt holes is cracked! leakagE!?
thanks al
