Author: Subject: x flow roller rockers
MkII
posted on 24/1/09 at 03:17 PM Reply With Quote
i have just fitted a set of titan roller rockers to my 1660 x flow and have found that the back of the rocker arms are touching the std steel rocker cover on full lift. has any one else experienced this. i have considered panel beating rocker cover to achive clearance but how much clearance do i need and you cant see how much clearance there is once the cover is on. any suggestions other than fit alloy cover as my upgrades list is allready bigger than my bank balance. thanx m.
prawnabie
posted on 24/1/09 at 05:05 PM Reply With Quote
On the cheap i would fit two gaskets lol.
But seeing as you have forked out for roller rockers, id go the whole hog and fit an alloy cover!
thunderace
posted on 24/1/09 at 05:27 PM Reply With Quote
can you tell me why you fitted titan roller rockers ???????????????
posted on 24/1/09 at 05:35 PM Reply With Quote
I would imagine for the same reasons that anyone else would fit them; more lift and less frictional loss.
You could see how much clearance is required by simply removing the rocker cover and tuning the engine over until you have max valve lift, then measure the maximum height of the rocker from the surface of the head. Subtract gasket thickness from this measurement and compare with the depth of the rocker cover.
[Edited on 24/1/09 by MikeRJ]
Memphis Twin
posted on 24/1/09 at 05:48 PM Reply With Quote
Roller rockers require an alloy cover. You can pick them up for £20 used. "Why spoil the ship for a halfpence worth of tar..."
MkII
posted on 24/1/09 at 05:50 PM Reply With Quote
Mike. its not height thats the problem its the back of the rocker arm just above the ball shaped bit on the bottom of the adjuster on full lift the rocker arm touches the side of the cover ----------------------------------------------
what MikeRJ said plus my rocker gear was quite worn so I decided to upgrade instead of replace. plus they were s/h, theyed done next to nothing and they were very cheap
[Edited on 24/1/09 by MkII]
posted on 24/1/09 at 07:31 PM Reply With Quote
also they are supposed to decrease guide wear due to not imparting sideways force onto the valve like what non-roller rockers do.
MkII
posted on 24/1/09 at 09:20 PM Reply With Quote
thanks guys,I suppose I allways knew the only real soloution to the problem was to fit an alloy cover,ebay here I come.m.
posted on 25/1/09 at 12:46 AM Reply With Quote
Ahh I see, that would be more awkward to to fix. Might be worth keeping an eye on this one.
MkII
posted on 25/1/09 at 12:54 PM Reply With Quote
cheers mike i'll watch that one.m.
