richard
| posted on 30/1/09 at 11:33 PM |
where are the bits on my twin 40's
Anyone know where i can get a diagram of the webber twin 40's we have just fitted and managed to get running on pinto, that will show me how to
do basic adjustment as they are running very rough and rich and will not tick over under 1200 rpm.
This will allow me to be able to drive it to get it tuned by local ish garage.
I have fitted a filter king fuel reg and this appears to be a bit below the 2.7psi have had recommended at present,even after adjusting the reg, but
that i do not think is the prob at present.
prawnabie
| posted on 31/1/09 at 01:12 AM |
Adjustments pretty limited to be honest! You need to whip the inspection covers off the top and see when jets you have fitted, someone on here will be
able to advise you some ballpark jets you can buy if you give a good description of your motor.
Shaun
greggors84
| posted on 31/1/09 at 03:43 AM |
This site has loads of exploded diagrams, heres the one for 40s
http://www.piercemanifolds.com/carbdetails/html/40_dcoe_151.htm
When I set mine up to get me to the rolling road, I used a guide from a book (one about engine management) this seems to be taken straight out that
book.
http://7faq.com/owbase/ow.asp?HowDoI%2FTuneWeberCarburettors
Chris
The Magnificent 7!
madrallysport
| posted on 31/1/09 at 08:58 AM |
Look at this link
Weber carb link
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
Dave Ashurst
| posted on 31/1/09 at 09:34 AM |
..and if you're still keen for more info after all that
edit: if you want a weber dcoe service manual u2u me your email address. Seems I'm not allowed to attach a pdf file here.
[Edited on 31/1/09 by Dave Ashurst]
snapper
| posted on 31/1/09 at 12:09 PM |
Jetting for standard 2000 Pinto ( a start)
34mm Chokes
135 mains
F11 emulsions
190 air correctors
35 accelerator pump
40 F9 idle
4.5 auxilary venturis
float level shut - 7.5mm
float height full droop - 15mm
idle screw 7/8ths turn
I eat to survive
I drink to forget
richard
| posted on 1/2/09 at 09:53 AM |
cheers all, as usual great response.
Richard.
