Author: Subject: Blacktop-Silvertop; What's the difference?!
Memphis Twin
posted on 1/2/09 at 08:05 PM Reply With Quote
Please excuse me if this has been covered hundreds of times before.
I'm an 8-valve pushrod kind of bloke (), but even I have to admit that some of these new (!) fangled 16v engines might be the way to go.
So what is the difference between a 2.0 Zetec Silvertop and a later Blacktop? I already have a registered car (with a pushrod engine of course) so don't need to worry about cats, sva and all that cr@p. I'd probably run one on quadruple Flatslides..or shock-horror a pair of ruddy great Webers Wouldn't want to get totally modern...
Cheers Chris.
omega0684
posted on 1/2/09 at 08:11 PM Reply With Quote
the blacktop is the newer of the two, blacktops have longer rods and lower piston crowns, mechanical rather then hydrolic lifters plus the distinctive black can cover and not the aliminium one found on the silvertop.
Read here
[Edited on 1/2/09 by omega0684]
posted on 1/2/09 at 08:16 PM Reply With Quote
Silvertop... has single piece cast ally sump, BT = two piece ally-steel pan sump.
Blacktop has longer con rods and shallow pistons for more revs...
Silvertop has hydraulic followers, BT solid with shims..
Blocks are slightly different... M10 threads in different position.
Oil pump different between all the different zetecs..
Different water pump..
BUT.. there is some difference between 1.8 and 2.0 silvertops as well... 2.0 sump deeper than the 1.8.. 1.8 water pump goes clockwise, 2.0 silvertop and BT go anti clockwise.
So.. if your thinking of changing go for the newest blacktop (Focus) you can find.
Memphis Twin
posted on 1/2/09 at 10:50 PM Reply With Quote
Thanks for your replies chaps. A blacktop it may well be then.
Wish they made a pushrod version!
Schrodinger
posted on 2/2/09 at 08:44 PM Reply With Quote
Have a look on http://www.zetec-cat.co.uk/ there is quite a good description of them both and the joys of fitting both
Keith
Aviemore
Memphis Twin
posted on 3/2/09 at 12:27 AM Reply With Quote
That's a very informative site. Thanks.
