Author: Subject: Pitted exhaust valves (zetec)
focijohn
posted on 5/2/09 at 04:25 PM Reply With Quote
Started lapping in my vlaves today and doing the exhaust valves after round one on the first exhaust valve its reasonably well pitted. So's the second and the third.
Is it worth replacing these or just give them a bit more?
I would try and get a piture but my dads camera has more settings than the space shuttle.
John
Anyone going slower than you is an idiot. Anyone going faster than you is a maniac.
Too many targets but too few bullets.
ashg
posted on 5/2/09 at 05:15 PM Reply With Quote
if its hydrolic just keep going. if you have shims dont go to far or you will have to reshim the tappets
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
focijohn
posted on 5/2/09 at 05:50 PM Reply With Quote
yea shes a silvertop
Danozeman
posted on 5/2/09 at 05:56 PM Reply With Quote
MIne were the same keep going. They will disappear with coarse then fine paste.
Dan
posted on 5/2/09 at 06:16 PM Reply With Quote
Note that simply grinding out the pits will recess the valves, and this reduces low lift flow a surprising amount. If they are bad it's best to the the seats re-cut and valves reground.
Schrodinger
posted on 5/2/09 at 09:55 PM Reply With Quote
I had a similar valve seats in an old Zetec head, had the head checked and reseated by a well known engine company, only to find that the head was cracked between two valves. I would get the head checked out before you go too much further if you havn't already.
Keith
Aviemore
