Author: Subject: 7.25" / 185mm clutches
flak monkey
posted on 6/2/09 at 05:35 PM Reply With Quote
Ok, so new flywheel takes 185mm race clutches, not a major problem.
One question though, are the drive plates interchangeable. I.e could I use a quatermaster plate in an AP cover?
Sera
http://www.motosera.com
24vseven
posted on 6/2/09 at 06:23 PM Reply With Quote
short answer is yes
but it depends on what type of set up is it full race ect how many plate system your running are you just using single plate or twin then are you useing ceramatalic plates or not as there is a diffrence in plate thickness
flak monkey
posted on 6/2/09 at 06:32 PM Reply With Quote
Single plate, organic material. So basically standard clutch material...
Sera
24vseven
posted on 6/2/09 at 06:41 PM Reply With Quote
so it looks like a normal clutch and pressure plate just smaller in which case yes should be ok as long as the thicknesses are simalar
flak monkey
posted on 6/2/09 at 06:47 PM Reply With Quote
OK thanks
Now I just need to find a reasonably priced supply...
Any recommendations?
Sera
24vseven
posted on 6/2/09 at 07:04 PM Reply With Quote
depends what engine / box you running i do have a full race ceramatlic clutch but there very harsh for road use
flak monkey
posted on 6/2/09 at 11:26 PM Reply With Quote
Will be running a 200bhp duratec mated to a hd type 9.
So basically looking for single plate organic 7.25" clutch with 1" x 23 splines to suit the type 9.
[Edited on 6/2/09 by flak monkey]
Sera
