daniel mason
| posted on 6/2/09 at 06:33 PM |
vaux red top
Hi guys,am wondering if many people on here have a 7 with 2.0 16v vaux red top engine? if so is there any rough performance figures you could give
(roughly 200 bhp)and any reliability issues i should be aware of. have only ever driven BEC but am interested in a change! its for fast road use only
and possibly 1 track dfay in the summer. thanks.
MikeR
| posted on 6/2/09 at 07:02 PM |
It should be around this point NS Dev will pop up and tell you about his.
Performance wise its BLOOMING FAST - something like 60 in 4 seconds, so as fast as a bike & you get the ability to cruise and go in reverse.
Issues are it only just fits under stuart taylor / caterham body work but you'll be fine with MK / MAC / MNR as they've got extra height
in the chassis and or body work.
cd.thomson
| posted on 6/2/09 at 07:11 PM |
Hey I'm building a C20XE Dax Rush. Out of interest how are you going to generate the 200hp, NA or blown?
As Im sure you're aware these generated around 150hp when new. I'm fitting throttle bodies, a big bore exhaust and an aftermarket ECU and
I'm hoping for 175hp at the wheels.
Once youve figured out the ballpark BHP youre going to end up with then its time to look at the average mass of your finished car. My Dax should
hopefully end up around the 650 - 700kg mark, not superlight, with some creature comforts but not overly so. Your car may be different.
Then head over to www.letstorquebhp.com.
Using my figures:
Power at Flywheel (BHP) : 200
Weight without Driver (KG) : 700
Power to Weight Ratio (BHP Per Ton) : 290.30
0 - 60 (Secs) : 4.17
0 - 100 (Secs) : 10.75
60 - 100 (Secs) : 6.58
Quarter Mile (Secs) : 12.57
Terminal Speed (MPH) : 108.14
Drag Strip Quarter Mile (Secs) : 12.47
Drag Strip Terminal Speed (MPH) : 109.44
(The bhp is at the flywheel not at the rear wheels)
This method applys to any car setup.
Craig
tomgregory2000
| posted on 6/2/09 at 07:48 PM |
cd.thomson wont all that differ with different wheel size, gearbox, diff ratio?
Daniel Mason are you fitting it to a car that is allready on the road?
cd.thomson
| posted on 6/2/09 at 07:54 PM |
You can call me Craig
Yep as with anything the number of variables is huge, even road surface is going to make a large difference.
the www.letstorquebhp.com calculator has a lot of information associated with it that explains that there a various fudge factors in the calculator.
They have used it on standard production cars to fine tune it.
I should have included a caveat that this should only be used for a ballpark figure. You can safely assume you wont hit 60 in either 1 second or 15
seconds, itll be somewhere around 4. You wont know precisely until its on the road
Craig
James
| posted on 6/2/09 at 08:06 PM |
Craig,
You'll have to fit plentyof luxuries to make it weigh 700kg!!!
James
- Muhammad Ali
skippad
| posted on 6/2/09 at 10:25 PM |
Built my first MK with an XE.
Twin Dellorto 45's, 175bhp, 0-60, 4-4.5 sec, loooaaads a torque, transX straight cut close ratio box, LSD........wished i never sold it
The only thing faster is me current MK with
ZX 1400 in it!
Daniel, the difference between the two is the former was relaxed cruiser with power when needed, the latter is more revs, revs, revs and more GRIN
factor!
BUT both excellent cars in there own right.
Would like to have both if i could... but me garage and pockets are'nt big enough
skippad
| posted on 6/2/09 at 10:29 PM |
Oh...and weighed in at 560kgs at SVA.
Lightened it a bit after, so prob about 550kgs
SALAD
| posted on 6/2/09 at 10:31 PM |
I'm using one.....that one <<< with DCOE's and megajolt.
179BHP on the megajolt map.......need to keep the weight down now and it should be 'interesting'
skippad
| posted on 6/2/09 at 10:38 PM |
BEST upgrade i made was the TransX straight cut box with long ratio first gear...
up to 60mph in first! all ratios all in right place.
Ditch that Sierra box.
MikeR
| posted on 7/2/09 at 12:16 AM |
I'm sure NS Dev's with posh throttle bodies and a good mapping session (plus ARP bolts) was a lot closer to 200 than 175.
cd.thomson
| posted on 7/2/09 at 09:00 AM |
At the wheels?
Theres a lot of debate over my figures, which i was just using as an illustration! A cossie rush is listed as 600kg, so it seems i was over generous
with the mass.
My logic is fairly sound for generating ballpark figures without any direct comparison though!
Craig
silky16v
| posted on 8/2/09 at 04:29 PM |
daniel if you need to know owt about the Vauxhall 2.0 16v XE let me know theres nowt much i haven't done with 1 of those engines i ran a 201bhp
Nova 2.0 16v for 18 months (2003) and i loved it and it was reliable for everyday use
oh it Matt who bought your car by the way
oh and if you need a motor let me know as bought a Astra Gsi that i'm breaking for spares, which i hope to rebuild and throw some bike carbs on
it with some alpha ignition management
[Edited on 8/2/09 by silky16v]
| posted on 9/2/09 at 01:33 AM |
At the wheels?
Flywheel. 200bhp isn't that difficult to extract from an otherwise standard 20XE with a decent exhaust manifold and throttle bodies, Check out
SBD's conversion.
MikeR
| posted on 9/2/09 at 07:35 AM |
Yep, flywheel.
cd.thomson
| posted on 9/2/09 at 06:49 PM |
Well thats quite exciting isnt it , I think hearing from others with built versions of what im building has to be the biggest motivation!
Craig
