Author: Subject: pinto differences
15111111
posted on 11/2/09 at 04:21 PM Reply With Quote
pinto differences
Hi I'm lead to believe there are 2 variations of pinto 2.0L onr of which has 205 on the block would one of u knowledgable people please enlighten me cheers Keith
whitestu
posted on 11/2/09 at 04:37 PM Reply With Quote
I'm no expert on Pinto's, but I think the 205 is the stronger block and was used in Cosworth engines.
Stu
mcerd1
posted on 11/2/09 at 04:40 PM Reply With Quote
205's are the later ones (mainly EFI engines)
20's are the early ones (carb'd sierra etc)
the 205 is a bit stronger / thicker / heavier (its the same as the cossie 2wd block)
jacko
posted on 11/2/09 at 04:43 PM Reply With Quote
Ford made 3 types
2l block capri / cortina
2l /205 block sierra
2l / 200 block these were for the cosworth
+ 1.3 / 1.6 / and 1.8 blocks
[Edited on 11/2/09 by jacko]
posted on 11/2/09 at 04:46 PM Reply With Quote
Originally posted by jacko
Ford made 3 types
...and unless you're looking at tuning it to a relatively high level or going for a bigger capacity bore then any of them will be perfectly OK to use - assuming of course it's in good condition!
Regarding the cylinder head, the injection head is said to flow better than the non-injectoin head due to better port shape. These are identified by the arched roof of the inlet ports as opposed to the flat roof of the non-injection inlet ports.
[Edited on 11/2/09 by nick205]
mcerd1
posted on 11/2/09 at 04:49 PM Reply With Quote
most of the 205's have a very large "205" cast into both sides of the block - you can't miss it
this book is a good source of info on pinto's linky
[Edited on 11/2/09 by mcerd1]
carpmart
posted on 11/2/09 at 04:53 PM Reply With Quote
So 1511111111111 - I was going to reply but in just 28 mins you have received a complete and accurate summary on Pinto blocks. LocostBuilders is a great resource!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
mcerd1
posted on 11/2/09 at 04:56 PM Reply With Quote
as well as the head the other main difference is the EFI engines have slightly stronger conrods
6700rpm for the early forged rods
6900rpm for the later cast ones
(according to the book anyway)
James
posted on 11/2/09 at 05:10 PM Reply With Quote
Also, IIRC, the 205 block is ok with unleaded.
James
mcerd1
posted on 11/2/09 at 05:29 PM Reply With Quote
James
not all of them
there is a code stamped on the head - I think the haynes books tell you what it means
vinny1275
posted on 11/2/09 at 09:14 PM Reply With Quote
Also, the Burton catalogue / website is a pretty good source of info on all the Ford engines, including a dating chart (for figuring out when they were built, not like blind date...... you know what I mean... )
Vince
