Author: Subject: zetec silver top and black top
Danozeman
posted on 15/2/09 at 07:28 PM Reply With Quote
Are the manifolds etc the same on both??
Dan
whitestu
posted on 15/2/09 at 07:43 PM Reply With Quote
Might not be exactly the same, but they are interchangable.
Is this linked to your carb problem?
Stu
[Edited on 15/2/09 by whitestu]
Danozeman
posted on 15/2/09 at 07:44 PM Reply With Quote
What needs to be changed to cobvert from silver top to black top?? Arnt the waterpumps different so you cant just fit a 1.8 one to turn the other way?
Dan
Dan
whitestu
posted on 15/2/09 at 07:49 PM Reply With Quote
On the blacktop an idler pulley is needed to run the water pump the right way. It's easy to do though.
I think the engine mountings will fit, but not 100% sure.
Stu
paulf
posted on 15/2/09 at 08:26 PM Reply With Quote
The alternator mount is different, the sumps are interchangable but the windage tray from the silvertop cannot be fitted to a black top without changing the main bearing studs.I modified the black top 2 part sump on mine , it needed a lot of ally cutting off and then the steel lower part was easy to shorten.
Paul.
