Author: Subject: Engine Flush - First time service
speedyxjs
posted on 15/2/09 at 07:48 PM Reply With Quote
One of my tintops has done very few miles (36000 in 11 yrs ) due to it being previously owned by my disabled grandad. The filler cap is covered in white crap due to the low mileage and i was told to use an engine flush to remove it.
I was told i need to drain the oil from the engine first then put engine flush in. Does this mean i need 3.5 litres of engine flush (car takes 3.5 litres of oil)?
Also i am going to service my cars for the first time (first time i have done it that is ) i know the above car was serviced 6 months ago but i dont have a record of what was done. Should i change the brake fluid and coolant anyway?
I dont want to go to the garage and ask them as they also service our vans.
phoenix70
posted on 15/2/09 at 07:51 PM Reply With Quote
Normally engine flush is about .5 to 1 litre so you need to make room in the engine for that. As for the servicing, normally they suggest changing the brake fluid every 2 years, but I'm pretty sure very few people do. I don't think you need to change the coolant any more regularly either.
speedyxjs
posted on 15/2/09 at 07:56 PM Reply With Quote
So you just add it to the oil already in the engine?
Thats easy enough
dmac
posted on 15/2/09 at 08:01 PM Reply With Quote
It sounds like they were talking about using flushing oil which is a very thin oil that you use to clean out an engine, you drain all your old oil but leave the oil filter in place, fill to the normal level with flushing oil and run the engine for about half an hour (do not drive anywhere) before draining again and replacing the oil filter and filling with normal oil. I don't know if you can still get flushing oil as most people use a flushing additive nowadays.
If you are going to use an engine flushing additive you can normally add it without draining the existing oil, the slight overfilling should not cause a problem for the short time it will be in the engine.
Duncan
speedyxjs
posted on 15/2/09 at 08:04 PM Reply With Quote
I think additive will be cheaper so il use that.
dhutch
posted on 16/2/09 at 12:07 AM Reply With Quote
When i did the pug, simualar miles in a simular time, no white junk but i think a few lapsed changed, i did a flush.
- Used 'wurth' flush i think, what ever pug suggest. £11 for a half liter.
- Ran the engine upto temp first (not mentioned) then added the flush and ran at a high idle for 5minutes or so. As per the instuctions on the can.
Drained as normal afterwards. Change filter, refill.
Daniel
Canada EH!
posted on 16/2/09 at 01:43 AM Reply With Quote
White crud is condensation, we get it in the airplane engine after flying through rain. Check for water leakage, or storage in very damp location. Flush the engine, new oil and filter then take it for a 1-2 hr drive at highway speed, check again. DO NOT PUT ANY LOAD ON THE ENGINE WHILE FLUSHING.
posted on 16/2/09 at 12:07 PM Reply With Quote
Best flushing additive is 500ml of autotransmision fluid -- it un-gums and frees off stuck hydraulic tappets like nothing else you can buy.
Add it to the sump then use the car for 1 day and drain when the engine is really warm.
