Author: Subject: Compression Testing
Howlor
posted on 17/2/09 at 08:52 PM Reply With Quote
Compression Testing
Hi All,
Normally compression testing is done while cranking. Is there a guide as to what percentage you would get turning over an engine by hand?
Thanks,
clairetoo
posted on 17/2/09 at 09:01 PM Reply With Quote
Probably not enough to measure - if you can turn it by hand .
Its cuz I is blond , innit
Claire xx
Will weld for food......
Aren't they normally with the engine hot too???
posted on 17/2/09 at 09:07 PM Reply With Quote
Only test you can if you can't crank the engines is a cylinder leakdown test -- really good thing to do on high performance engine to monitor the engines condition.
Leak down tester cost about 60 pounds upward but it is easy to make your own
