bjohnson
| posted on 25/2/09 at 03:32 PM |
2.0 Pinto. 5 speed convershion
Hi Guys. I would like to fit a 5 speed gear box to my 2.0 Pinto. I believe this a fairly common mod? I have got hold of a 5 speed type 9 gear box. I
see the input and output shaft are different to my 4 speed. Anybody know if I can just use a different clutch? Which one?
| posted on 25/2/09 at 03:39 PM |
You should just need the clutch to fit the 5 speed input shaft. Is that bjohnson of London Mayor standing, are we going to see Locosts exempt from
congestion charge then Boris ?
cd.thomson
| posted on 25/2/09 at 03:40 PM |
I didnt think they were different?
Oh unless youve managed to get your hands on the stronger v6 one? If so you need to get the input shaft machined IIRC
top few sentences of this post:
http://www.turbosport.co.uk/showthread.php?t=103512
Craig
Paul TigerB6
Well the 2L pinto and 5 speed box (you have a type 9 or MT75??) were used in the Sierra so thats got to be the obvious answer. There are a few options
for the flywheel / clutch / release bearing so ensure its all matched. What flywheel are you using currently??
Dont forget your propshaft too.
[Edited on 25/2/09 by Paul TigerB6]
omega0684
| posted on 25/2/09 at 03:56 PM |
if you are going to replace the clutch you only need to get a std 2.0 pinto clutch, from burton power they are about £80
mcerd1
| posted on 25/2/09 at 04:00 PM |
I'd guess that your old 4 speed box has a 7/8" input shaft with 20 splines
and a type 9 has a 1" shaft with 23 splines (as does the MT75)
have a read at these: (down the left side of the page)
http://www.burtonpower.com/technical_1/technical_articles_default.aspx
so assuming its a type 9 and you have a std. manual pinto flywheel - you need a different friction plate and maybe release bearing too (or the whole
clutch kit to make it easy) - one from a sierra should do the trick, 2.0L 1982-86 (i.e. one with a pinto)
and a prop of course
[Edited on 25/2/09 by mcerd1]
bjohnson
| posted on 26/2/09 at 10:12 PM |
Thanks guys good stuff
