nib1980
| posted on 2/3/09 at 06:22 PM |
Help with my Stupidity
Hi All
Now please ecuse my stupidity, but i was given some original weber trumpets and told they were for my DCOE40s.
they are the slot in type.
But for the love of me they don't seem to slot in.
The OD of the trumpet is 44.95mm (are these for 45s?)
Or are you suppsed to disassemble the carbs or something?
I mean i measured the DCOE inlet and its got a taper on it down to around 37mm (but i thought this was the choke.)
HELP please wth my stupidity
Many thanksNeil
flak monkey
| posted on 2/3/09 at 06:36 PM |
Yep, they are for 45's.
Sera
http://www.motosera.com
nib1980
| posted on 2/3/09 at 06:43 PM |
but by my reckoning i need slot in ones that are 36mm, which is not a dcoe 40 then?
flak monkey
| posted on 2/3/09 at 06:46 PM |
The butterfly should be 40mm od.
I think the bores of the carbs are parallel other than the choke, but could be wrong. Dont have any tomeasure up for you anymore
Sera
nib1980
| posted on 2/3/09 at 06:51 PM |
Cheers david,
Do you have or know where i can get a diagram so i can check.
An Does any one wanna swap these 45's for some 40's?
i can get some piccys if they do
Paul TigerB6
| posted on 2/3/09 at 07:16 PM |
Do you need any help with your stupidity?? Arent you already stupid enough as it is??
nib1980
| posted on 2/3/09 at 07:28 PM |
good point!
Paul TigerB6
| posted on 2/3/09 at 07:32 PM |
good point!
Couldnt resist sorry - it was just asking for it!!
DIY Si
| posted on 2/3/09 at 07:35 PM |
Have a look at this:
Piece 18 is the bit you're on about and it butts up against the leading edge of the choke, and as such is the same diameter as the carb, ie
40's take a 40mm bell, 45 a 45mm.
Sun Tzu, The Art of War
