hobbsy
| posted on 5/3/09 at 10:10 AM |
Fancy Red Line diff oil?
I should soon have my shiny new Quaife ATB in my 3.38 7" Sierra diff.
I know it only needs normal EP90 oil as the Quaife diff is an ATB not an LSD that requires special oil.
However I'm sure I remember reading a lot of the RGB boys run fancy Red Line diff oil as its claimed to reduce transmission loses etc.
Something like this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=400011054735
they do a few different versions.
Or I may just go for the Silkolene stuff that Quaife recommend:
http://www.quaife.co.uk/Silkolene-Silktran-SYN-75W-90-synthetic-gear-and-transmission-oil-per-litre
I guess that might be the safer option rather than going for something too thin in the search of 0.01 bhp
| posted on 5/3/09 at 10:28 AM |
I've got the Superlightweight stuff in my diff. It's amazing smelling stuff!! I think in my diff I probably need lightweight rather than
super as it crashes a bit when taking up the backlash, I suspect if I had thicker oil it wouldn't do that. I also had a problem with the diff
oil escaping as vapour via the diff breather. In the end I put a long breather hose on the end of the breather nipple and that stopped it.
