eddie99
| posted on 7/3/09 at 10:02 PM |
Cable Hydraulic Clutch Question
Hiya Guys
Im just about to decide what todo, i have a hydraulic pedal box and hydraulic master cyclinder but am using a type 9 gearbox which was originally
cable.
I have the option of just adapting my pedal box and having a cable system.
Or i have been told you can get some converter that attaches to the gearbox to make it hydraulic. I have done a bit of searching around but
haven't really found much.
What have other people done? and does anyone have any links of sites who sell this "adaptor"
Any help appreciated, Thanks
Ed
Dingz
| posted on 7/3/09 at 10:59 PM |
Just have a cable on my type 9, most of the 'new' systems use a concentric cylinder behind the clutch release bearing, I am sure you
could sort something out to do it that way. But I am in the process of converting a metro gearbox to hydraulic using a Willwood pull cylinder from
Rally Design pt. no. 260-1333 and thinking it might be easy to use on a type 9?
blakep82
| posted on 8/3/09 at 01:17 AM |
a few pictures of how i did my
hydraulic clutch
the cylinder is a mondeo one
________________________
AdamR
| posted on 8/3/09 at 09:25 AM |
I'm also going the pull-type slave route - my thinking being that a concentric cylinder would be expensive, difficult to fit and difficult to
maintain.
Linky to Wilwood
| posted on 8/3/09 at 09:30 AM |
On the other hand a cable is cheap, reliable and easy to change if it fails . Concentric cylinder is likely to be expensive, need an adaptor to mount
to the gearbox and a lot of work to change if it fails. Pull type ram has some of the latter points as well.
clairetoo
| posted on 8/3/09 at 09:32 AM |
Her's mine - corsa cylinder onto an Mx5 `box (no room for the release arm without cutting the chassis )
  Slave cylinder
[Edited on 8/3/09 by clairetoo]
Its cuz I is blond , innit
Claire xx
Will weld for food......
ss1turbo
| posted on 8/3/09 at 09:38 AM |
I know someone who'd used the Wilwood-type pull cylinder on a Zetec/Type 9 combo and says it works well. Not in a Locost, but a Rover P6..
Edit: Just had a quick search through my emails and apparently works spot on with a 0.75" master cylinder.
This one was from southwestspeed, i think:
[Edited on 8/3/09 by ss1turbo]
Long live RWD...
