Author: Subject: Help - Oil contaminated clutch - recoverable?
Dave Ashurst
posted on 21/3/09 at 05:30 PM Reply With Quote
As the title says really.
Is it possible to clean a car clutch plate that's been soaked in oil?
If so how?
It's an AP Racing one so quite expensive, and only 2 months old.
tia
Dave
blakep82
posted on 21/3/09 at 05:31 PM Reply With Quote
if its soaked i'd have thought its had it...
brake cleaner might be your best bet though?
________________________
chrisg
posted on 21/3/09 at 05:32 PM Reply With Quote
I've been told that soaking in dry cleaning fluid followed by a thorough drying works, but I haven't personally tried it.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Jon Ison
posted on 21/3/09 at 05:39 PM Reply With Quote
Pepsi max, honestly, always had a bottle in the tool kit in my grass tracking days, cures a wet slipping clutch in nanoseconds.
I had a RV8 fastened to a Audi box in a class ten, oil seal leaked for a whole season, coke down hole before each meeting job done, guess I should have repaired seal but coke was easier.
edit to add, put a proper engine in, they like oil on the clutch..........
[Edited on 21/3/09 by Jon Ison]
Dave Ashurst
posted on 21/3/09 at 05:52 PM Reply With Quote
Wow, thanks guys. Plenty to play with there!
I feel better already.
D
prawnabie
posted on 21/3/09 at 05:53 PM Reply With Quote
Problems dave?
Dave Ashurst
posted on 21/3/09 at 09:01 PM Reply With Quote
Originally posted by prawnabie
Problems dave?
Hi Shaun,
Yes. A bit too much oil outside the engine for my liking.
Hopefully all of it came from a leaky end cover seal on the new high pressure oil pump on the new engine.
The only time I've ever I left the clutch arm gaiter off the bvellhousing. Oil everywhere under the car and dripping off everything. I cleaned off the oil and replaced the pump but it was too late. On Thursday, going home from work on the motorway the clutch started slipping on acceleration.
Nothing a quick engine and gearbox out and in again won't solve I guess plus some heavy duty cleaning solvents
I just hope the crank seal is ok.
Or perhaps I'll just shake and squirt a bottle of pepsimax into the bellhousing ..
D
goaty
posted on 21/3/09 at 09:57 PM Reply With Quote
boiling it in water is best bet, but that means getting it out....
prawnabie
posted on 21/3/09 at 10:51 PM Reply With Quote
Thats a pity dave, I am off out in the locost tomorrow and was going to head over your way!
May well go to Bridgnorth now or somewhere nearer the welsh border if the weather holds out!
Shaun
Ninehigh
posted on 22/3/09 at 06:57 AM Reply With Quote
So the coke thing actually works? Cool I was thinking it might have been one of them BS mails that go round
Dave Ashurst
posted on 22/3/09 at 07:33 AM Reply With Quote
Shaun
You're more than welcome to call over anyway. I'll get a bottle of pepsi max from the co-op for the car.
Jon Ison
posted on 22/3/09 at 10:10 AM Reply With Quote
You must have tried the 2p left in a glass of coke thing ?
If not try it, may put you off drinking coke when you see the results.
Ninehigh
posted on 22/3/09 at 10:25 AM Reply With Quote
Yeah done that. It jams up the coinstar machine
