spud69
| posted on 23/3/09 at 09:58 AM |
Megajolt map
Megajolt query
Just a quick question:
Got megajolt all up and running on a 2.0l zetec with bike carbs except the tps on the chart is not travelling the full scale only from 10 to 20%. The
rpm is advancing fine. I've calibrated the tps and it works fine on the analogue readout on the software.
Cheers..Andy
| posted on 23/3/09 at 10:58 AM |
Best place to ask would be the MJ forum, here (if you haven't already).
spud69
| posted on 23/3/09 at 11:08 AM |
Thanks, i've now done that. Didn't realise that forum was there.
| posted on 23/3/09 at 11:47 AM |
It's a good place to know about if you're a MJ owner! The designer, Brent Picasso, is always on there to answer questions and he's
very good at finding solutions for people.
mad4x4
| posted on 23/3/09 at 12:59 PM |
check that you are getting a good vacum to the megajolt. if you have a vacum leak then this will cause this.
Scot's do it better in Kilts.
spud69
| posted on 23/3/09 at 05:57 PM |
Cheers but its working on tps rather than map so shouldn't be an issue.
