Author: Subject: crossflow thermostat housing to radiator pipe?
posted on 3/4/09 at 12:39 PM Reply With Quote
errr, thinking of replacing my hoses by blingy silicone ones.
I believe Ford uses 32 mm for a lot of its cars (old ones anyway) and that appearswto be the case for the radiator and water pump, but on the crossflow thermostat housing, I measure to be 40+ mm!!?!?!
Do you try to push on a 32 mm hose or use an reducer 40 -> 32 mm are available.
and is auto-performance on ebay the cheapest place for silicone hoses?
[Edited on 3/4/09 by 02GF74]
Davey D
posted on 3/4/09 at 01:51 PM Reply With Quote
it will be much easier to use a reducer than struggling to stretch a silicone tube 8mm oversize. Ive found they dont tend to have that much stretch in them. especially not when you talking abour pipe as small as 32mm
cjtheman
posted on 3/4/09 at 04:19 PM Reply With Quote
hi there the thermostat housing is 32mm on the crossflow i have just changed mine to samco
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
chris_smith
posted on 3/4/09 at 06:11 PM Reply With Quote
auto performance are also mr silicone on ebay and i think there is another name which is the same people, so shop round between the shops once you have a list that you need
cheers
chris
