Author: Subject: Airbox
rsmith95uk
posted on 5/4/09 at 01:58 PM Reply With Quote
Airbox
has anyone utilised bike carbs and the associated airbox on their CEC?
I've got ZX6 carbs and am looking for a way to avoid building one myself.
Ray
[Edited on 5/4/09 by rsmith95uk]
gingerprince
posted on 5/4/09 at 04:04 PM Reply With Quote
I would have thought (though I'm no expert!) that it wouldn't be a great idea to use the bike air box. The volume of airboxes is fairly critical to ensure it's tuned for resonance at the optimal rpm for the engine. The air box will be tuned for a 600cc engine at a particular rpm, whereas a CEC engine will be much larger, therefore sucking in more air and needing a larger volume.
There are formulae around the internet for calculating the size of airboxes etc, so you could measure the volume of your airbox (fill it with water or something) and see how that correlates to the optimal size you calculate for your engine.
Or you could just stick it on an see what happens
DIY Si
posted on 5/4/09 at 04:44 PM Reply With Quote
I'm not sure how much it will affect things really, given that although the engine is bigger it will be turning less RPM, so the air requirement should be similar. The main issue may well be in fitting the box itself, as they tend to be an odd shape designed to fit around the fairing and under the fuel tank.
Sun Tzu, The Art of War
tomprescott
posted on 5/4/09 at 06:14 PM Reply With Quote
What about one of the sock filters that itg/weber/piper-x make? Or, small indiviual conical filters.
Don't know about the practicality of a bike airbox but they are as ugly as sin!
