jollygreengiant
| posted on 13/4/09 at 03:41 PM |
Johhny5 carb help (ZX6) ? anyone
I have just been over to see johhy5 where he is building. He has a problem with his bike carbs. He is using ZX6 carbs but I think he has a fault with
the carb for Number 4 cylinder.
The engine now ticks over fine (timing adjusted and carbs reasonably balanced), however when you accelerate the engine the slide/piston on number 4
cylinder fails to raise like all the others. I have pulled the top cover off and had a quick look at the diaphragm. This looks reasonably OK with no
obvious splits or holes. Neither does there appear to be any air leaks, the engine base idles too well for that.
However, when you just gently lift the piston (with the engine OFF) there is a noticeable (lower/less) difference in the effort required to lift the
piston compared to the other 3. It is almost as though there is diaphragm.
I have never played with these carbs before so I am on unknown territory compared to a lot of you out there. Is there something simple that I have
missed.
Your opinions would be gratefully accepted.
| posted on 13/4/09 at 03:47 PM |
Is it worth swapping the piston and cover from one of the other carbs to check if it is at fault ? Could it be an engine or intake problem?
jollygreengiant
| posted on 13/4/09 at 04:03 PM |
I did think about doing that but I didn't want to disturb the other pistons/diaphragms in case I made matters worse.
I am fairly sure that it is NOT an engine problem as it idles TOO well for that and he has a nice even colour on the stainless exhaust pipes which
tends to indicate an even Idle burn across all 4 cylinders. It is ONLY when you accelerate and hold higher revs that he starts to get unevenness
and a misfire on number 4. It is drawing a good vaccuum on that cylinder because you can see the fuel being pulled out of the main jet around the
needle. Its just NOT lifting the piston. Even without the balance spring in the top of the chamber.
| posted on 13/4/09 at 04:19 PM |
Air leak at the diaphragm?
johhny5
posted on 19/4/09 at 08:50 AM |
Sorted it,
just needed to put a little grease around the top of the diaphram and the plastic cover to get a good seal, now working good , cheers
John
