<<  1    2    3  >>
Author: Subject: Really peed off now
flak monkey
posted on 15/4/09 at 05:25 PM Reply With Quote
Really peed off now
I have, quite frankly, had enough of the GTS now
I cannot fix this erratic rpm issue, all the suggestions have been tried and many more to boot. As far as I can see there is nothing wrong with any of the ignition or fuelling system.
All of this leaves me with a car which is undriveable at motorway speeds with Stoneleigh less than 3 weeks away.
So fed up now
Sera
http://www.motosera.com
jacko
posted on 15/4/09 at 05:29 PM Reply With Quote
Calm down have a cup of tea and start again
Guinness
posted on 15/4/09 at 05:35 PM Reply With Quote
3 weeks? Plenty of time to get that Duratec in then!
Mike
flak monkey
posted on 15/4/09 at 05:39 PM Reply With Quote
When its not under load the engine kind of hunts, which suggests to me that the ignition timing is fluctuating. Under load you just see sharp rpm spikes and misfires.
I am seriously considering fitting the edis, but if I screw it up there's no going back and certainly no time to fix it before stoneleigh.
If a std dizzy fixes it then I can live with the performance hit until the duratec is installed.
Sera
James
Could you borrow enough bits off other MS pinto engined people to keep swopping bits out to isolate the problem further.
Have you posted it up on the MS forum as well? To get the opinions of the likes of Bill Shurvington(sp?) etc. on it?
Wish I knew enough MS to help you!
Good luck,
James
piddy
Hi. Just remind me again what your running? Is it Pinto,MS,Edis,throttle bodies?
or Mega jolt and Carbs
omega0684
posted on 15/4/09 at 05:44 PM Reply With Quote
piddy : he is running tb's and MS to control the fueling with electronic dizzy for ignition
flak monkey
posted on 15/4/09 at 05:45 PM Reply With Quote
Hi Martin, Running pinto with megasquirt doing fuel onlyon gsxr 750 TBs and H&H ignition solutions electronic dizzy which was brand new when I built the engine.
Have posted the problem on the MS forums here, have had a few suggestions, but only one guy seems to be bothered:
http://www.msextra.com/viewtopic.php?f=4&t=30851
Got my post removed from the std MS forums as I have an extra ecu, not that I am using that bit of it!
Sera
MautoK
posted on 15/4/09 at 05:47 PM Reply With Quote
Don't worry, you're not alone.
My MK has been on the road since the 3rd of April, 12 days, and I've done 12 miles in it so far. At the moment the engine and box are coming out of the car so I can put another gearbox in.
Having holed the gearbox sump pan on my first drive, then fixed that, on the second try it wouldn't change out of first gear
Apart from that, it's brilliant, and worth the grief!
John.
flak monkey
posted on 15/4/09 at 05:48 PM Reply With Quote
The most annoying thing is I had a similar issue on carbs which turned out to be a loose rotor arm, but I dont know if that was hiding this problem or not. Wish I had the carbs here now to find out!
Anyone got a pair of DCOE's set up for a pinto I could borrow? LOL
Sera
Gazeddy
posted on 15/4/09 at 06:00 PM Reply With Quote
would i be right in assuming youve checked for vac leaks
piddy
I don't think I can help. I do have a pinto Dizzy you can borrow if it would help. Have you tired Different plugs and plug leads? Have you spoke to Phil at Extra EFI
www.extraefi.co.uk
flak monkey
posted on 15/4/09 at 06:06 PM Reply With Quote
I would expect, if I had a minor air leak for the engine to hunt at idle and for my AFR to be all over the place. I will investigate though. I dont understand how it could cause rpm spikes at only certain RPM.
I havent spoken to Phil at extra efi as the ecu is one of Bill Shurvingtons IIRC. I'll mail him and see if he has any suggestions though.
Sera
piddy
posted on 15/4/09 at 06:08 PM Reply With Quote
I Spoke to Phil when I had problems and my unit was from the US. He was really helpful and even offered to take a look at the MS for me. He came to one of our meetings as well.
hellbent345
posted on 15/4/09 at 06:12 PM Reply With Quote
bad news chap was it like this when you took me out? i didnt notice anything if it was! hope you get it sorted soon
Alan
flak monkey
posted on 15/4/09 at 06:13 PM Reply With Quote
Alan
Hi Alan, yes it was, but I managed to hide the problem then. Its ok when accelerating hard, but bad when cruising at high rpm....
Sera
flak monkey
posted on 15/4/09 at 06:14 PM Reply With Quote
Thanks Martin, I will send him a mail.
Sera
sebastiaan
posted on 15/4/09 at 06:17 PM Reply With Quote
Could you convert to EDIS? the big advantage is that this used OEM equipment for the "difficult" part (i.e. measuring engine speed and determining TDC correctly on a running engine). For the Duratec you also cannot use a distributor engine speed input, you'll need to go 60-2, probably using wheel decoding (that'll be lots of fun too!)
I'm using MSExtra (fuel and spark) on a pinto myself, triggered by an injection dizzy with external coil amplifier (bosch type). After LOTS of fiddling i'm still not impressed with the stability of the RPM signal and the ignition advance. I'd very much prefer an EDIS setup, but have got other things to do at the moment....
DIY Si
posted on 15/4/09 at 06:23 PM Reply With Quote
Does it hunt when it's on the driveway, or only under load/driving? Would it be possible to get a 'scope on it to double check the coil?
Also, is there anyway the dizzy drive can slip on a Pinto?
Sun Tzu, The Art of War
flak monkey
I can convert to edis (and plan to use edis on the duratec too and already have an edis sitting next to me on my desk) but if that doesnt solve the problem then I am royally screwed as I wont have time to try anything else before stoneleigh.
The other issue is my MS ecu will need modifiying to work with EDIS and no-one can tell me what I need to change. The instructions on the MS Extra wesbite dont tell you what the starting point is for the mods, and it seems no one does! My ecu currently has twin coil drivers built in.
Sera
flak monkey
posted on 15/4/09 at 06:25 PM Reply With Quote
If you rev it over 3500 on the drive the revs jump about and it seems like the engine is hunting. Underload its sharp rpm spikes on the datalog and feels like the engine is missing.
Dizzy is driven by a worm gear on the pinto, so it can't slip.
Sera
brianthemagical
posted on 15/4/09 at 06:26 PM Reply With Quote
You say on the MS forum topic that the dash shows the spike, is this a tacho seperated from the MS.
Sounds like it's nothing at all to do with the MS, more the coil.
What about trying a timing light, see if it's giving dodgey spark.
You could always run with a toothed wheel if needs be.
Are you sure the dizzy is wired up correctly? Maybe be talk to H & H but just say you've got RPM spikes on the tacho, but don't metion the MS and see what they say.
Is there any reason you're not using spark from MS? Would be much better in the long run.
I know how you feel though, it's so frustrating that there's a problem with electroics that you can't alter or fix, and that cost a fair few pennies. It's a mega good feeling whne you finally win, good luck.
flak monkey
posted on 15/4/09 at 06:33 PM Reply With Quote
The dash shows the spikes too, which is connected direct to the coil and not driven by the MS.
I am no longer convinced its an MS issue either and more a problem with the distributor in some way.
Could a faulty coil cause the same problem? That was also brand new and is a cossie type dry coil rather than a std wet type
Sera
gregs
posted on 15/4/09 at 06:36 PM Reply With Quote
Flak - try running it with the lights off - guessing might be ht lead break down??, or just get a new set to rule out. Mates 911 had something similar and it lit up like a fireworks display in the dark with the lid open.
[Edited on 15/4/09 by gregs]
sebastiaan
posted on 15/4/09 at 06:38 PM Reply With Quote
I trust you've seen this: linky
I thought that is all you need to know. As far as I can see, the hardware changes should be very limited. What hardware are you running?
The tach spikes you are getting are normally closely related to the distributor RPM input option. Are you still running fuel only or fuel and spark?
You'll get it sorted out, don't worry!
<<  1    2    3  >>
