blakep82
posted on 19/4/09 at 03:28 PM |
zx9r carb jammed
i've got a set of zx9r carbs, with TPS, and on the 4th carb (furthest from the TPS sensor) the butterfly spindle is jammed. as far as i can see
its on the end of the carb (ie not the side where the linkage joins the 3rd carb, if that makes sense)
how do i get the little end cap off to look inside, and is it reusable again? do i need to put one on if i can't reuse it?
whats likely to be the reason for it being jammed?
________________________
dinosaurjuice
| posted on 19/4/09 at 03:54 PM |
ive heard rumours that a backfire can sometimes bend a carb spindle or butterfly. maybe its true?
blakep82
| posted on 19/4/09 at 04:15 PM |
well, its been sprayed with all manner of things, WD40, 3 in 1 oil, and now wynns carb cleaner. its freed up a little, leaving it to soak over night
in wd40 now, i'll have another go at it tomorrow. looks like it may just be varnished up from sitting for a while. i'm not sure how loose
it should be though. it can't be turned by hand yet though, so still too tight i guess?
blakep82
| posted on 19/4/09 at 06:31 PM |
its getting left in all sorts over the next few nights
wd40 tonight!
