Marlon
posted on 25/4/09 at 01:09 PM |
setting float levels
What a PITA, I'm not having fun at all today, I seem to have been at one carb for hours now and still not got it right. Does anyone know a
simple way to set the levels on a set of zx9 carbs? any help greatfuly recieved before I give it up as a bad job and have a beer!!
cheers
john.
[Edited on 25/4/09 by Marlon]
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
Stott
| posted on 25/4/09 at 04:44 PM |
All the carbs I've ever done had a seam along the plastic float that needed to be set parallel to the float bowl mating face, this equalled the
manufacturers measurement for height.
Of course using the std method,
carbs off
bowls off
tilt the carb so the float causes the fuel supply stop to seat but the spring doesn't compress
bend the tang one way or other until float sits parallel to mating face
repeat
HTH
Stott
| posted on 25/4/09 at 04:47 PM |
Here's a good guide that gives float heights for keihins that I have used over the years on KTM dirt bikes:
http://www.carbparts.com/keihin/needles_tuning/jetting_your_carb.htm
