grassracer
| posted on 28/4/09 at 11:16 AM |
Pinto Electronic Ignition
I'm currently running a points dizzy on my 2.0 Pinto powered race car but want a cheapish swap for electronic, I'm assuming some Sierra
models had electronic ignition so are these a straight swap and will the advance curve etc be the same, I don't want to be losing power, just
gaining a bit of reliability!! I don't suppose anyone has the bits I need for sale do they???
blakep82
| posted on 28/4/09 at 11:32 AM |
i don't know much about pintos or sierras, but i would assume the electronic ignition was on injected sierras. might not be a simple swap. it
depends on whether the ignition and injection systems were seperate or not
________________________
flak monkey
| posted on 28/4/09 at 11:48 AM |
all pinto sierras had electronic ignition. Look for an escII module one, nice and simple.
Having said that if you dont have probs with the points, I would leave it. But you say its a race car, mapple ignition is the way forward if you want
to unlock the power, or get in touch with H&H ignition solutions and see what they have.
I will have a spare electronic pinto dizzy from H&H available in a few months if interested?
[Edited on 28/4/09 by flak monkey]
Sera
http://www.motosera.com
dave r
| posted on 28/4/09 at 08:11 PM |
ive got a spare dizzy and amp available now
DarrenW
| posted on 28/4/09 at 10:28 PM |
Std ford gear will work ok. Davids H+H is a good improvement over std ford for a modded engine. I opted for megajolt in the end, fairly easy and has
worked well.
