rosey1
| posted on 28/4/09 at 05:15 PM |
really had it now
as posted before had loads of problems with the 2ltr pinto went for stage to head and fast road cam and brand new twin choke webber and caint get it
to run right its been to its fourth garage today and they cant find whats wrong and charged me another £80 dont know what to do next .even thinking of
putting another engine something like ztec depending on cost
tomprescott
| posted on 28/4/09 at 05:50 PM |
I agree with ^^^. If the cam isn't right, or if you're block wasn't at TDC when the head went back on then thats most likely the
cause.
What carb are you using? Weber? While to get the most out of your Carb you need to get it RR'd you should be able to easily get the engine
running by yourself.
First off, check which jets you have and then search on google for which jets other people have used.
Look online for a tuning guide for your carb and follow it for the idle and mixture screws, on my weber 2 to 2.5 turns out on the mixture screw got it
starting but check online for the specifics for your carb.
Good luck, Tom
flak monkey
| posted on 28/4/09 at 05:53 PM |
There isnt much to go wrong with a pinto.
Check cam timing - could be one tooth out
Ignition timing - stable and not fluctuating
Fuel supply (if its running out of fuel it will miss) - pintos are fairly unfussy to be honest
Spark - is the distributor suitable for the engine tune? If you have a std one you will need to run 8deg advance at idle to avoid too much advance
under load. BUT this isnt enough idle advance with a fast road cam, which really needs 14deg at idle to run properly. Make sure you are running
WITHOUT vacuum advance.
Sera
http://www.motosera.com
austin man
| posted on 28/4/09 at 07:27 PM |
Have you checked for air leaks in the inlet tract ??
your timing may would deffo be the area to look along with dizzy cap rotor arm if fitted etc. You dont mention whether it ran okay befor the mods, did
it??
rosey1
| posted on 28/4/09 at 07:32 PM |
it was running fine before the mods its a 32 36 dgv carb and i am sure every one has told me to check the vacume advance is working before
austin man
| posted on 28/4/09 at 07:38 PM |
my zetec had a simmilar problem when I first got it running, it fired up and ticked over a little lump but still it ran it died when the acceleartor
was pressed, turned out the firring order was wrong effectively firing 180 degrees out of sync easy fix I just cut two of the wire feeding the coul
pack and hey presto. Have you tried changing the plug leads round ? is the firing order correct
rosey1
| posted on 28/4/09 at 07:53 PM |
yes put new leads on what bit did you cut and i live in scunthorpe
rosey1
| posted on 28/4/09 at 07:54 PM |
how much will it work out to put a zetec in
austin man
| posted on 28/4/09 at 08:03 PM |
I cut the leads from the ecu to the coilpack as there there is no distributor on the zetec.
You would need to change the leads around on the distributor to achieve the same thing. I think the firing order for the pinto is 1342 change the
leads around so 2 replaces 1 and 4 replaces 3 and see if that works for testing for air leaks on the inletside get the car running and spray wd40
arount the manifold joints if the speed increases you hav an air leak.
PS I would trust Anthony's judgement from fast road cars he seems to be the oracle of all thing Webber, he sorted my jets out just by me telling
him engine size and spec mine are 40's.
cost to change to a zetec could include bonnet if yours is cut, new engine mounts, new water pump, spiggot bearing, clutch plate, engine mounts, new
side panel as exhaust exits opposite side. then theres the engine say £150 and an ECU £300 and upward ,
rosey1
| posted on 28/4/09 at 08:17 PM |
yes that is who i got carb off realy nice bloke but its being to 4 garages and they say carb but i am not sure what to think now
jpindy3
| posted on 28/4/09 at 08:27 PM |
timings out jumped a tooth when putting the head back on,no bigie,not alot gos wrong with pintos ,it can all be fixed
snapper
| posted on 28/4/09 at 08:45 PM |
Put the original carb back on, if it runs beter its the carb.
Cam timing,
Rocker gaps (a 285 runs closer than standard,
strobe the spark timing to check what the distributor is giving.
check points gap and dwell.
make sure all inlet and exhuast manifolds are air tight.
Check all electrical conections, even a slightly dodgy earth can result in problems.
I know as i am still chasing a problem
So far i have found:-
dodgy megajolt loom (sheilding not earthed properly)
Vacuum takeoffs slipping off
base ignition map too retarded
coil pack problems
plug fouling due to rich mixture
leaky inlet manifold to carb rubbers
idle speed to low
under bonnet heat to much
block breather to restictive
2.1 engine built without decking the block resulting in low compression
will it ever end........
I eat to survive
I drink to forget
ditchlewis
| posted on 28/4/09 at 09:02 PM |
i'm with flack monkey, is the fuel pump up to it? i had allsorts of problems before i changed to an electric fuel pump (the mechanical one was
leaking air). also had a faulty spark plug.
good luck and sticck with it, it will be easier to solve the problem than change the engine altogether.
ditch
iscmatt
| posted on 28/4/09 at 09:07 PM |
my problem with the pinto was the cam, it wasn't lined up to the pulley on the outside, it looked right from the outside but was way out!
DarrenW
| posted on 28/4/09 at 10:37 PM |
It should be possile to get a pinto to start and tick over even if the timing is a fair way out - albeit badly. So as said already go right back to
first principles and set the static timing up, then check advance etc once fired up.
Its very easy to get the dizzy 180 deg out. They dont run when that happens.
I guess it will be hrd to start if carbs are well out too, but for starters check the static engine timing then research the starting point for carb
settings to get you somewhere near.
Ignition amps can fail, assuming you have the std ford electronic set up (dizzy with plug on end of lead - not the one with plug built into dizzy
body)
DarrenW
| posted on 28/4/09 at 10:40 PM |
Sorry, but this made me a chuckle. Bit like triggers famous quote on Only Fools and Hoses when he was telling delboy that he had had his broom for
years, its only had 6 heads and 4 handles in 20 years (or something like that)
