Author: Subject: Mondeo slave. Which master?
owelly
posted on 28/4/09 at 07:04 PM Reply With Quote
I have a Mondeo concentric clutch slave cylinder fitted to my type 9 box but at the moment, it's operated by the old (1970's Alfa!) master cylinder. The problem is that the pedal only moves half of it's travel to operate the clutch. I've had to make a stop to prevent the slave from popping out. Obviously, the M/C is too large. What size bore should I be using?
Cheers, Owelly.
http://www.ppcmag.co.uk
blakep82
posted on 28/4/09 at 09:09 PM Reply With Quote
0.7 was recommended to me for the racing trucks, but i don't know what slave they use. can't be too different to the mondeo one (which i'm using too) although its not plumbed up yet.
thats maybe not a whole lot of use but what diameter is your current master cylinder?
[Edited on 28/4/09 by blakep82]
________________________
owelly
posted on 29/4/09 at 07:58 PM Reply With Quote
The current one is 3/4". About 0.75.......and it's waaaay too big!
I've been reliably informed (Cheers Trev) that an Astra one may be the way forward!
