The Baron
| posted on 29/4/09 at 06:03 PM |
My Pinto is nearly dead.
My second Pinto engine in 1 year is about to expire, so I have been collecting together the parts to install a Zetec in the near future.
I have the fuelling sorted by using an adaptor plate to enable me to install my 32/36 dgav (which was band new 500 miles ago)
Engine mountings, are designed & partial fabricated (cant finish until I get the engine in the car)
New gearbox support bearing purchased.
A ford coil pack
A starter from a Diesel escort.
The exhaust I shall make.
But!!!!!!!
In the true spirit of the locost, what is the cheapest & easiest way to get some ignition on the go? I can’t really afford the mega jolt jobber.
Is there any cheap and cheerful method using scrap yard parts?
B
bob
| posted on 29/4/09 at 06:13 PM |
Using the coil pack you have it is possible to run a 2D ignition set up from ( now i will probably be corrected on this ) a fiesta/escort.
Try a search on zetec ignition wiring,i did have all the info on my old pc and sadly havnt kept any notes.
Sorry but the best i can do
r1_pete
| posted on 29/4/09 at 07:02 PM |
Its the Ford ESC unit you need from a carbed Escort/Orion/Fiesta.
I just happen to have one with the loom plug and a circuit diagram.
U2U me if you're interested, I'm sticking with MJLJ and bike carbs for now.
jpindy3
| posted on 29/4/09 at 08:15 PM |
as r1 pete said,i got on aswell you can have
