dhutch
| posted on 4/5/09 at 11:26 AM |
Joining coolent hoses.
What do people use for joining 3/4" hoses?
Im replacing a few older hoses with new ones, and as is common, im using a combination of performed bends (cut of other hoses) and straight sections
of coolent/heater hose.
1/2" you can use 15mm copper water pipe fairly well i guess. And you can get custom cnc'ed aluminum joiners from the silicon hose
brigade.
But im just wondering what most people use and a cost effective but unbodged looking solution?
Daniel
A1
| posted on 4/5/09 at 11:28 AM |
look on car builders solutions or demontweeks.
i have some aluminium ones, about 4 quid each.
MikeR
22mm copper pipe - if you get the stuff that pre-soldered it comes with built in ridges for you
| posted on 4/5/09 at 11:33 AM |
3/4" is 20mm (near as dammit) so 22mm should fit. It'll be a tight squeeze and you might need to warm the hoses first in some boiling
water to make them fit over the 22 pipe (use some antifreeze as lube as well).
Silicon pipes are more flexible so will take +/- quite a few MM easily (depending on the tube diameter)..
dhutch
| posted on 4/5/09 at 01:26 PM |
Fair enough.
- Oddly i hadnt even thought of using 22mm copper pipe! I guess theres no issue with copper in the cooling loop as long as its clean because its all
delt with with the inhibtors in the antifreese?
The hoses dont creep off under the pressure without a barb or flareed end?
Daniel
MautoK
| posted on 4/5/09 at 02:43 PM |
Cross-sectional area of 22mm pipe is about 0.6 sq inch, so a pressure of 15 psi gives a force of about 9 pounds.
If you can secure the hose to withstand a ten pound pull you should be OK.
I find that roughing the end of the copper tube, a smear of Hylomar jointing compound and a good quality Jubilee clip works every time.
John.
| posted on 4/5/09 at 03:00 PM |
Pipes blowing off is never a problem with traddional rubber hoses --- silicone seems to be a different matter.
iank
| posted on 4/5/09 at 03:40 PM |
Daniel
As MikeR says use the pre-soldered ones and you get the flares for free
See http://www.screwfix.com/prods/47218/Plumbing/Solder-Ring-Fittings/Flowflex-Straight-Coupling-22mm-Pack-of-10
If you want you can replace the straight runs with 22mm copper tube, fewer jubilee clipped joints.
[Edited on 4/5/09 by iank]
Anonymous
dhutch
| posted on 5/5/09 at 12:38 PM |
quote: As MikeR says use the pre-soldered ones and you get the flares for free
Yeah, i was just worried about geting the pipe of the aditional diameter of the joiners (which are more than 22mm od) rather than the pipe. BUt i
guess i can get a pack of ten from the aformentioned store at lunch and give it a go!
Daniel
