Author: Subject: pinto cr
jpindy3
posted on 7/5/09 at 06:01 PM Reply With Quote
pinto cr
hi all,can any one tell me what my cr is,its a 2100 fart road pinto,i used a guage and it read 200psi,i dont know how to convert it
thanks
jamie
jpindy3
posted on 7/5/09 at 06:19 PM Reply With Quote
yep its a new type of pinto tuning,you got to use the tank as a tolet
il give steve at vulcan a ring,
ta
jamie
Richard Quinn
posted on 7/5/09 at 06:34 PM Reply With Quote
Unfortunately it's not that simple. You will also need to know a lot more about your engine (bore, stroke, volumes (combustion chamber, piston shape etc), deck height etc) before you can convert.
jpindy3
posted on 7/5/09 at 06:36 PM Reply With Quote
oh
The Baron
posted on 7/5/09 at 06:47 PM Reply With Quote
My standard 1600 pinto runs at 170 psi.
200psi is 13.7895146 bar
enter the following into google to convert anything:-
convert 200psi to bar
i just find it easier to work in bar
then measure the bore, bit of math, job done....
B
[Edited on 7/5/09 by The Baron]
jpindy3
posted on 7/5/09 at 06:49 PM Reply With Quote
ok can anyone tell me roughley its about 150bhp @ the fly,id say its 10 somthing???????????
[Edited on 7/5/09 by jpindy3]
flak monkey
posted on 7/5/09 at 06:51 PM Reply With Quote
It will be in the region of 9.1:1 to 9.5:1 presuming the block has been decked to suit the 2.1 rebore. It could be higher if the heads been skimmed as well, which can take it to 10.5:1
Too high for any serious amount of boost. You really need to lower it to about 8.5:1 and use forged rods and pistons (cossie ones would fit a std block, but not a 2.1).
[Edited on 7/5/09 by flak monkey]
Sera
http://www.motosera.com
posted on 7/5/09 at 08:18 PM Reply With Quote
First of all it depends hugely on the cam. A long duration cam will considerably reduce the static CR since the valves won't seal until well after the piston has started it's compression stroke.
Then you have the calibration of the pressure gauge, some of them are absolutely dire, but it doesn't matter for testing for cylinder variation.
Next you have the good old gas laws hampering the situation. Unless you compress a gas very, very slowly to give an isothermal process, the gas heats up (adiabatic heating). This naturally increases the pressure given a fixed volume.
A genuine 150bhp Pinto (which is a fairly rare device), will have a high static CR, at least 10:1 and probably a bit fair more than that.
[Edited on 7/5/09 by MikeRJ]
jpindy3
posted on 7/5/09 at 08:36 PM Reply With Quote
why is a 150hp pinto rare its 1600quid from vulcan bit more if you want 160hp,this is at the fly,still150hp at the wheels isnt rare,mark the owner of escort tec has a 210hp n/a pinto in his escort
jamie
snapper
posted on 7/5/09 at 09:11 PM Reply With Quote
A proper 210 out of a Pinto would cost well over £5000 probably closer to £10000
You can't just bolt bhp to a Pinto, 130bhp is pretty easy, getting a proper 150bhp, matching all the bits and getting set up is going to cost, I already have a pile of bits worth £600 sitting in my workshop, i have bike carbs, Megajolt, light flywheel and vernier from the current engine. I expect 150bhp, I will be exstatic if i get more. What i am going to do is make sure i can drive the car on the road, I don't want an engine that only starts to produce power at 4000rpm but one that will still drive relatively easily but rev to 7500.
The current 285 cam is very easy in a light car, my other cam, an RL22 may be a bit cammy but i will give it a go.
I eat to survive
I drink to forget
jpindy3
posted on 9/5/09 at 06:56 PM Reply With Quote
ok well,as i said i got my pinto from vulcan engineering costing 1600quid with no ancillaries, bike carbs 320 from gbs,lumition 280 with leads,i wont go any ferther the engine is 135bhp with the std pinto carb put webbers on that gives 150,and bike carbs give about the same as webbers 150bhp!
as for the 210bhp pinto its made by aaron at ht,no dout he spent a sh*t load of cash on it
jamie
posted on 9/5/09 at 08:30 PM Reply With Quote
Because unless you were a) barking mad or b) were running in a series that demanded a Pinto, your £1600 would buy you a vastly better engine capable of considerably more power without touching the internals and would be lighter, more economic and and more reliable.
Most supposed 150bhp Pintos are nothing of the sort (though Vulcan do have a pretty good reputation).
[Edited on 9/5/09 by MikeRJ]
jpindy3
posted on 10/5/09 at 10:37 AM Reply With Quote
thats a bit harsh,thanks for your usless post im not really botherd what you think,
im well happy with it and pintos all round,
also as im lerning this motor is a good start,when i got it i didnt know how to change the oil filter,now i have got another pinto a 202 block and have striped it and rebuilding it and fit a turbo,
no dout your gona slag this off as well.
[Edited on 10/5/09 by jpindy3]
