jpindy3
| posted on 11/5/09 at 08:07 PM |
im fed up got iva on the 20th and
i am stuck,ran out of money,
the bottom hose on my pinto is being a b*tch with clearance next to the fan belt ,i need some ford wheels with good tires on,as one of my rear wings
is 5mm sorter wieth than the other and my alloy and tire wall is proud,need to fix my indecator wires on the inside of the nose cone!
and i have 8 days to do it in
ive had it,with this blud*y car!!!!!
jamie
[Edited on 11/5/09 by jpindy3]
macspeedy
| posted on 11/5/09 at 08:08 PM |
where are you based?
jpindy3
| posted on 11/5/09 at 08:10 PM |
horsham,west sussex
| posted on 11/5/09 at 08:12 PM |
dont panic mate, someone can lend you bits to keep you moving.
handyandy
| posted on 11/5/09 at 08:17 PM |
shame you,re not closer, would gladly help.
i have 4 ford fitment wheels/tyres that you could use for a while, they are 14in x 6 ( or 6.5, ), got good tread etc.
andy
jpindy3
| posted on 11/5/09 at 08:19 PM |
that would be cool,
the thing is now thay put the price up of the iva to 450 and the retest is 90,
all in all its not far off 900quid,inc insurance,
and another 90 on top!
its gona brake my bank
mr henderson
quote: Originally posted by jpindy3
,i need some ford wheels with good tires on,as one of my rear wings is 5mm sorter wieth and my alloy and tire wall is proud,
Make sure the camber on the rear wheels is set correctly, if the wheel is leaning outwards at all then the wheel will be pround of the wing.
Also, got to your 'control panel' button(up in the top right corner of this page), and update your profile to show your location
John
handyandy
| posted on 11/5/09 at 08:25 PM |
what size wheels do you need? if i,ve got them then you are welcome to borrow them .
andy
RichardK
| posted on 11/5/09 at 08:33 PM |
Dunno if this is of help but this is how I did my lower hoses.
Unfortunately for you I can tell you what they are off as I was given a bag full of assorted hoses that I could hack together and join with tube a
jubilee clips, what I can tell you this works well as I don't have any problems with cooling at all.
Rich
Gallery updated 11/01/2011
jpindy3
andy
hi andy, my wheels are 195-50-15,i need a skiner and smaller set,sorry i dont know wheel sizes 14in would be good
mr henderson
| posted on 11/5/09 at 08:38 PM |
andy
You haven't said if you've checked the camber yet. Indy's can usually take 195's no problem. Check to make sure the wheel
isn't leaning out
John
[Edited on 11/5/09 by mr henderson]
macspeedy
| posted on 11/5/09 at 08:40 PM |
for the rad hose i bought a ribbed flexible one from halfords
handyandy
| posted on 11/5/09 at 08:42 PM |
andy
well i,ve got a set of 14in wheels with i think 185/65 profile ( wheels are at my lock up 7 miles away), ford fitment with VERY good tread on tyres
(budget tyres) , if we can find a way to get them to you then no prob, wonder how much city link/tnt etc would charge???
you sure 14in would clear your wish bones/suspension set up?
cheers
andy
jpindy3
| posted on 11/5/09 at 08:48 PM |
andy
You haven't said if you've checked the camber yet. Indy's can usually take 185's no problem. Check to make sure the wheel
isn't leaning out
John
the wheels are bolt upright,and the wheel is about 6-7mm proud can i ajust this,i dont have a clue about ajusting camber
jamie
mr henderson
| posted on 11/5/09 at 08:54 PM |
Check that the car is on a level surface. Use a spirit level to check. The use it to check that the wheel is upright. If it is leaning outwards then
you can adjust it inwards by using the adjustment at the top of the upright. Undo the locknut, wind it in a but then retighten and recheck
John
jpindy3
| posted on 11/5/09 at 08:55 PM |
andy
cheers
andy
i dont know andy,
il have to ask mk,
handyandy
Hey Jamie,
i,ve just looked at your archive pics & your car looks great, don,t despair.
the things you mention that need doing.... is that all that needs sorting for the iva test?
andy
jpindy3
| posted on 11/5/09 at 08:58 PM |
John
no mate thay are bolt upright,
i dont know any more
fu*k sake
handyandy
| posted on 11/5/09 at 08:59 PM |
ok ,
does anyone on the forum know if 14in wheels are able to fit?
if you don,t find out tonight then yes contact MK tomorrow,
i,ll confirm the size of my tyres & get a price from city link ref the cost to get them to you .
if you U2U me your mobile i,ll get info to you tomorrow.
andy
jpindy3
| posted on 11/5/09 at 09:03 PM |
Hey Jamie,
andy
i have changed it quite alot since that pic,for the test.
ie mirrors,steering wheel,
there is a list edges ,god my minds gone blank.some other stuff
jamie
jpindy3
| posted on 11/5/09 at 09:04 PM |
do i need a exhaust cover?????
| posted on 11/5/09 at 09:14 PM |
ok ,
andy
13" wheel will fit on the (Sierra based) Indy as will 14, 15, 16 and 17" wheels.
I've got 195/50x15" wheels and tyres which fit absolutely no problem. Camber is set to around -1 degree (leaning in at the top) this
should give ample clearance.
Have you got any wing piping between the bodywork and the rear arch? That will give you a fraction more spacing to work with too.
What needs sorting on the front indicator wiring? I have plenty of bit and pieces, a soldering iron, crimpers etc so if I can make something or send
something to help then just shout. Any pics of what you need to do would help
Bottom rad hos is a PITA around the fan belt and steering column. I used a Gates flexi hose from halfords 38mm dia at water pump and 32mm other end,
linked to a 90 deg hose bend on the rad outlet with a length of ally pipe. It's not that neat but it does work.
Get some photos up on this thread and let us know what you're struggling with.
And...keep it up, the elation when you get there just makes all the grief melt away
Nick
eznfrank
| posted on 11/5/09 at 09:15 PM |
No as long as it passes radius - it got removed from final IVA manual.
handyandy
i think this requirement has been removed from the new iva rules.
U2U me your mobile number if you want me to give you the info on tyres tomorrow & the transport options.
andy
ps, without sounding cheeky, take a deep breath & have a beer / coffee etc. its just pre test nerves. said politely.
jpindy3
| posted on 11/5/09 at 09:25 PM |
thanks for all your help,
im tired so im off,
jamie
