Author: Subject: Fitting bike carbs
Miks15
posted on 16/5/09 at 08:31 PM Reply With Quote
Fitting bike carbs
Hi all,
Couple questions about fitting my bike carbs
1. How crucial is the angle of the carbs?
2. What thicknesses should the follwing be?
a) Manifold plate?
b) Manifold tubes?
Mikkel
mr henderson
posted on 16/5/09 at 08:33 PM Reply With Quote
Good if you can get them to the original angle, but doesn't matter too much. Thickness of the plate and tubes doesn't really matter either, thicker stuff is usually easier to weld, and a bit sturdier.
John
omega0684
posted on 16/5/09 at 08:40 PM Reply With Quote
i would be better to get the carbs as close to the original angle as that is the way they are designed, remember the float chambers are designed to be at that angle.
Miks15
posted on 16/5/09 at 08:43 PM Reply With Quote
How do i know what the correct angle is?
What is the usual thickness used?
omega0684
posted on 16/5/09 at 08:48 PM Reply With Quote
what carbs are you using?
i think that most people could with a 4 or 5 mm plate for the mounting face to the block and about 1.5 or 2 mm should be plenty for the inlet tubes
[Edited on 16/5/09 by omega0684]
Miks15
posted on 16/5/09 at 09:16 PM Reply With Quote
there gsxr600 carbs
jacko
posted on 16/5/09 at 09:19 PM Reply With Quote
Look in my photos under zx9r / manifold
it will help you
Jacko
Miks15
posted on 16/5/09 at 09:47 PM Reply With Quote
had a quick look jacko, your manifold looks great!
Does the inside need brazing and machining like you have done?
jacko
posted on 17/5/09 at 08:11 AM Reply With Quote
Hi no you dont have to braze it but it just makes the tubes smoother inside
