MkII
| posted on 17/5/09 at 05:57 PM |
fuel leak
having trouble with fuel leaking from between my webber 40s and manifold have checked and double checked float level and replaced misab plates and
mounting rubbers. it doesnt leak while stood ticking over outside garage but when you come back from a hoon around underside of carbs manifold is wet
with fuel.any body got any ideas its got me stumped!.thanks in advance. m.
jpindy3
| posted on 17/5/09 at 06:30 PM |
dont scrach you head and light a fag!!!!!!!!!!!!!
check it ant coming from the inlet pipe?
[Edited on 17/5/09 by jpindy3]
mark chandler
| posted on 17/5/09 at 07:09 PM |
If you overtighten on the manifold they leak.
You just fasten until the special washers are closed but the carbs still feel loose on the rubbers
MkII
| posted on 17/5/09 at 07:58 PM |
I used the rubber bobin type things with the 2 tin cups and tightend bolts untill there was 2mm gap between cups I dont think they are to tight. m.
