Author: Subject: has anyone ported there own head DIY
jpindy3
posted on 19/5/09 at 11:06 AM Reply With Quote
I got a really good book on it,and was thinking of giving it a go.
anyone done this???
omega0684
posted on 19/5/09 at 11:09 AM Reply With Quote
dude check out my pinto rebuild thread in the 'engine and transmission' section, look at part 4: Porting
here
Alex
JAG
posted on 19/5/09 at 11:12 AM Reply With Quote
Yep I had a go.
I can't say that it definitely made a difference but it hasn't spoilt anything and I learnt a lot about my engine and head whilst I was in there
I have some photo's in my Archive of the head before, during and after. Some shots showing the valve shrouding on the MX-5 engine, some showing the bare head, shots down the ports and the final head chamber volume measuring set-up I used.
I picked-up 3 Tungsten carbide burrs on Ebay for about a fiver and used these in my electric drill. They certainly chewed through the aluminium of the ports - you have to be very carefull
ETA: the pictures are in the 'General Stuff' folder.
[Edited on 19/5/09 by JAG]
Justin
Dangle_kt
posted on 19/5/09 at 11:13 AM Reply With Quote
yup, but it was a motorcycle engine.
Its pretty easy as long as you have the right tool for the job, and repeat over and over as you work, "I can take more off, but I can't stick it back on"
Just make sure you understand where the valve guides etc are, so as not to compromise the reliabilty of the engine.
Triton
posted on 19/5/09 at 11:14 AM Reply With Quote
Good few years ago yeah, ported a Mini head using Vizards wicked book of making the A series go a wee a bit quicker..
www.tritonraceseats.com
www.hairyhedgehog.com
posted on 19/5/09 at 11:23 AM Reply With Quote
Me and my brother did some porting on an A Series head with a 100Watt Minicraft drill (well before Dremels etc. became available and popular). Used the David Vizard bible as per Triton, and the engine went very well.
posted on 19/5/09 at 11:36 AM Reply With Quote
anyone done this???
I thought about it but I couldn't get the dremel past the ear wax.
tegwin
posted on 19/5/09 at 11:37 AM Reply With Quote
There is an article somewhere.... someone used water and a sheet of glass to volume balance the combustion chambers in the head..... Amazingly simple!......
Using a titration tube to measure the volume of each chamber and removing material to balance them!
www.verticalhorizonsmedia.tv
mad4x4
posted on 19/5/09 at 11:41 AM Reply With Quote
Is that not called Trepanation
Linky
[Edited on 19/505/09 by mad4x4]
Scot's do it better in Kilts.
JAG
posted on 19/5/09 at 12:38 PM Reply With Quote
Yes, that's what I did. Water with a little anti-freeze to colour it.
[img][/img]
Justin
flak monkey
posted on 19/5/09 at 01:32 PM Reply With Quote
Yep, the best book is How to powertune Ford pinto SOHC engines by Des Hamill. Very clear and good advice
Sera
http://www.motosera.com
