Author: Subject: Pinto Cam belt
splitrivet
posted on 20/5/09 at 08:01 PM Reply With Quote
Pinto Cam belt
Just had a thought as to why my pinto's running rough.
Is a 2 litre cam belt the same size as a 1.6 ?
Bob
Marlon
posted on 20/5/09 at 08:07 PM Reply With Quote
I thought a 1.6 belt was 1 or two teeth shorter but not 100% sure.
john
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
lotusmadandy
posted on 20/5/09 at 08:09 PM Reply With Quote
The 165 engine uses the same cam belt
as the 205 engine but the early 1600
and 2 litre have a different belt.
RichardK
posted on 20/5/09 at 09:33 PM Reply With Quote
I have an early cam belt if you need it.
Rich
Gallery updated 11/01/2011
snapper
posted on 20/5/09 at 09:47 PM Reply With Quote
Erm...... cam belt length should not cause problems.
Its only the drive gear and cam gear size that dictates rotational variance, the belt only delivers the drive from crank to cam, the tensioner compensates for different lengths of belt (within certain tolerances), if you skim the head it would retard or advance cam timing a bit.
most likely you could be a tooth out when you fitted the cam belt, no big deal on the 2.0L pinto (valves wont contact piston) but makes a difference on the running.
Check cam timing and move cam sprocket back or forward a tooth.
I eat to survive
I drink to forget
sickbag
posted on 20/5/09 at 09:53 PM Reply With Quote
Might be worth investing in a vernier pulley so you can dial the cam in, regardless of the belt used.
Finally back on the job!
splitrivet
posted on 20/5/09 at 10:32 PM Reply With Quote
It is about a tooth out, I was assured a 1.6 cam belt was the same size as a 2.0, I just thought I had done something wrong.
Is it a 2.0 belt you have Rich, not a 205 block by the way.
Bob
RichardK
posted on 21/5/09 at 12:01 PM Reply With Quote
if yours isn't either a 165 or 205 block then the one I have will be the correct one you need.£8 posted?cheers Rich
